Recall 2011-2014 F250-F550 6.7L 14E03
  #421
Old 02-25-2015, 11:00 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
I had my truck in - finally - for an oil change plus the reflash. The dealer is 30 miles of mostly open road driving. I zero'd the Lie-o-meter just to check fuel mileage each way. Going, cold engine, 41*F oil @10*F ambient to start out with, it was 16.7 mpg. After the reflash and traveling the exact same route plus being stuck behind the same @#$% 18 wheeler for about the same number of miles, the Lie-o-meter registered at 19.4 mpg though with a warm engine and 23* ambient. WOW!! 2.7 mpg better. Yep, at least today. Do I believe that is 'real life'? Only if I believe in the tooth fairy and Santa. Shifting 2-3 seems a little stronger and a throttle dead spot has disappeared plus the idle speed is back where it belongs at ~600 rpm instead of 900-1100 since really cold weather has been here. I was also able to get a copy of the OASIS - looks like the PO had some problems with the CAC, NOx sensors and the turbo right after it was delivered tho I've not had any.
Oh and no regen nor any low DEF warnings yet
  #422
Old 02-25-2015, 11:02 AM
chperry's Avatar
chperry
chperry is offline
Had the recall done last week (Friday). First regen today. It lasted 24 minutes and peak temp on EGT4 was 1200 degrees F. 24 minutes seems like a long time to me but I admit I didn't pay a lot of attention to the times before.
  #423
Old 02-27-2015, 09:51 PM
MTalley's Avatar
MTalley
MTalley is offline
2013, 49k miles and had ours reflashed while in for other maintenance.
1. Seems to be an improvement in mileage while towing. Not phenomenal, but noticeable (maybe 1/2 to 1 mpg). Today we had a decent headwind and still got just over 10 mpg (16k fifth wheel).
2. We've always had a pretty good "bark" sound on a 3-4 upshift when towing. Haven't heard it at all since the flash (crossing my fingers on this one).
3. Today while towing and running with cruise on and in tow/haul mode, the truck downshifted itself eventually to 3rd gear (running 55) to retard speed going down a pretty good interstate grade. I never remember it dropping more than one gear before, eventually allowing the truck to keep gaining speed until I intervened.
We haven't driven enough unhitched to comment on regens or bobtail mileage. Will see how it does in the longer term.
  #424
Old 03-01-2015, 08:57 PM
Powerstroke67's Avatar
Powerstroke67
Powerstroke67 is offline
I had this recall done on my 2011 F-350 and its been doing a continuous regen and i can't get better than 150 miles out of a tank of fuel. My dealer doesn't have a clue why it will not come out of regen. Has anyone else had this issue??
  #425
Old 03-01-2015, 09:14 PM
Dakster's Avatar
Dakster
Dakster is offline
Someone else posted an issue like that. I am surprised that your Ford dealer has not called Tech support. Ford HQ has a bunch of engineers to help them out when they get stumped.
I am thinking on the modules that needed to get updated didn't take the update, but that is just a SWAG at this point.
  #426
Old 03-01-2015, 09:19 PM
Rick03hd's Avatar
Rick03hd
Rick03hd is offline
Originally Posted by Dakster
Wonder if now the 2011-2014's will get the long regens now and worse mileage.
I had mine done and have been in Regen for 2 weeks
  #427
Old 03-01-2015, 09:46 PM
Powerstroke67
They have called and Ford hasn't come up with a resolution other than "you'll have to change the PCM, DPF unit, and a bunch of sensors" all for $12,000. I'll buy a Dodge before I put that kind of money into this toilet.
  #428
Old 03-02-2015, 05:26 AM
Irelands child
Two new guys with the same problem. hmmmmmm
Oh and that's on Ford's buck to fix the problem, not yours. If they resist, your friendly lawyer can handle the problem
  #429
Old 03-03-2015, 05:59 AM
bbaudoin's Avatar
bbaudoin
bbaudoin is offline
I got the letter and need to get in to get the flash done. I have a 2012 with 42k miles. Looks like I also have the dreaded radiator leak. I do have an extended warranty. I just noticed last night that I have another leak. It's coming from the area around the windshield washer reservoir on the passenger side. I can see the water dripping off of the frame rail. Hopefully, I can get this all taken care of soon. It's a great inconvenience and disappointment.
  #430
Old 03-03-2015, 09:02 AM
vloney's Avatar
vloney
vloney is offline
Every body needs to calm down
<table width="100%" align="center" border="0" cellspacing="0" cellpadding="2"> <tbody> <tr class="rsstitle" valign="top"> <td width="88%" height="23"> Mar 03 2015 6082-2011-2014 6.7L F-Super Duty Built On Or Before 11/06/2013 - Instrument Panel Cluter Drive To Clean Exhaust System Message After PCM update From FSA 14E03
</td></tr> <tr class="rssbody" valign="top"> <td width="88%" height="24">Some 2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine and built on or before 11/6/2013 may exhibit a “Drive To Clean Exhaust System” in the IPC after completing FSA 14E03. Service Tip: Ensure to Perform a Diesel Particulate Filter (DPF) Manual Regeneration and DPF Parameter Reset to clear this message. The adaptive learn tables for the Diesel Particulate Filter (DPF) are not reset during PCM reprogramming and will need to be reset/cleared to prevent this message from being set falsely. Reset/clear the DPF parameter tables and perform the DPF Manual Regeneration with Integrated Diagnostic Service (IDS) tool by selecting the following: Toolbox, Powertrain, Service Functions, Diesel Particulate Regeneration System, DPF Parameter Reset and DPF Manual Regeneration.</td></tr></tbody></table>
  #431
Old 03-03-2015, 09:21 AM
Irelands child
Calm down? Just saying it the way it is. Two brand new guys show up and complain, one of which says that a Dodge may be in his future. Amazing that those folks are never taken to task and will quite possibly never be seen again as happens so many times on a product specific forum.
Oh and my May 2010 build 2011 6.7 after Recall 14E03 was made has not even gone to regen yet in about 150 miles
  #432
Old 03-03-2015, 10:29 AM
SultanGris's Avatar
SultanGris
SultanGris is offline
That seconds one is your air conditioner, lol
  #433
Old 03-03-2015, 12:56 PM
bbaudoin's Avatar
bbaudoin
bbaudoin is offline
That's funny Sultan. It's not cold here in TX, but not that warm either. Definitely not the AC.
I'm going to re-fill the washer reservoir tonight to see if it leaks more or holds the fluid.
  #434
Old 03-03-2015, 09:25 PM
Powerstroke67
I'm not going anywhere. I've actually been a member for a few years, just not very active. The truck is built Ford Tough for sure but I can't say that for the engine and emissions system. I've had 5 turbo's done and a handful of injectors(truck didnt even have 100 miles and it needed 2 injectors), a EGR cooler, multiple SCR temp sensors, urea level sensor, and a urea injection hose. I'm a long time 6.0L tech and master transmission rebuilder, but I'm still learning about this new engine. I love the 6R140 transmission along with the 5R110, huge improvement over tye E4OD/4R100
  #435
Old 03-04-2015, 10:52 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
When are you headed in to the dealer, bbaudoin? I'll be able to research ways to help once you've received a diagnosis. Keep us posted.
Crystal
Quick Reply: Recall 2011-2014 F250-F550 6.7L 14E03
