Stuck in Park Again!!!!
My 2012 F250 6.7 once again (third time in 2k miles) got stuck in park with no brake lights or traction control. I found that removing the shroud from the steering wheel allowed me to manually activate the solenoid and get into gear but could only drive in manual shift mode.
Something is causing the brake switch fuse to blow. When I replace the fuse all is well for maybe 1k miles then it happens again! After the second time I replaced the brake switch thinking it was the cause but no deal. It happened a third time. The dealer who fixed it the first time could not find the cause.
This is frustrating and downright dangerous! What in the circuit could be causing the short? Any ideas?
Rob
Rob
That is a bugger. Gremlins like this are very hard to deal with.
There are a few folks who have had problems with shorted wires/systems and the problem area is above the riverside front wheel well and under that brake fluid/fuse panel.
Also, there can be issues above the passenger wheel well if I remember right. May as well remove the wheels, wheel well liners, and methodically inspect all those harnesses carefully. I'm not sure where the bcm and pcm are but I'd trace them down too.
Rob
Crystal is a huge help and should be able to get you somewhere with your local dealer. Is the truck not still under warranty? If so I'd let the dealer do the head scratching on this one. Have you tried putting 1 size bigger fuse in that slot? Although it's not a proper fix it might just be a mild short that is a little bit more than the current fuse can handle and might not be a major concern. I had a similar issue on a previous vehicle and I never could trace the problem because it was so random. I opted for a 20 amp fuse instead of the factory 15 amp and it never had another issue. Best of luck.
Let's get you escalated up to the customer service manager for your region. Send a PM my way with your full name, best daytime phone number, VIN, current mileage, and servicing dealership; I'll push this up the chain.
Crystal
Crystal can send you a PM that you can reply to, but I don't think she's here on the weekends.
I agree with Joel, this is most likely a wiring issue. And in your shoes I'd be more concerned about the lack of brake lights than getting it out of park, that puts yourself and whoever is behind you in danger.
Apparently I need at least 5 more days as a member before I can reply to your PM. This is OK as I am hitting the road and heading back to my service area so will be driving. I will reply when I get there and my time has accumulated.
By the way it happened again!
Thanks,
Rob
