Radio with Cassette
Hmm, that's a tough one, especially if it's not stock.
Have you tried pushing everything? Because with these, or something similar to them, I recall having to push both the rewind and fast forward buttons at the same time to eject it. That, or, pushing either the left or right **** in.
If none of those work, I would try to push in on the tape to see if that releases it. I know some old tape decks used to work that way, kinda like with some VCR's too.
this one here only has one button you slide it to the left or right for Rev or Fwd and press straight in for play. Not sure as I haven't tried putting a tape in yet, the USPS hasn't came yet so I don't have the cheap tapes I got off ebay to try it. Don't want to try some of mine as they were hard to find when they were new and have them destroyed by a tape player that might not even work.
But I got this from a radio shop that claimed it was rebuilt.
If it was rebuilt, there's a pretty good chance in my eyes it will work (they should have replaced the dry-rotted drive belt).
I guess its not rebuilt. Unless sitting on the shelf caused it to mess up. The Rev/Play/Fwd button does not pop out anyfurther when you put the tape in. The tape is kind of hard to insert but it does start to play and after about 2 seconds it pops out and stops playing.
It appears that the farther in reel is not spinning resulting in the tape bunching up and causing an auto eject.
So it looks like I will be pulling the radio out and taking it back to that place and pay them to go through it. One thing I know is the volume **** theres a spot where when you hit it the volume does not change then it starts changing again after 1/8 turn further. Then the pushbuttons don't work, I recall they worked when I got it but now they don't. Then theres this tape issue, I want this radio to atleast function like it did when new.
This one is only around $32.00 and has all I need. It has the aux input on the front to accept all types of players. http://www.mcmelectronics.com/produc...6MUA-/60-10315
I've got the same radio in my 84. On mine, you push both buttons with the arrows on them, to eject a cassette. The cassette player on mine doesn't work, it will start to play, and then stop. Eject the cassette, and sometimes the radio comes on, sometimes not.
One question I have, on mine, you can push the volume **** in, what does that do?
