A4LD not releasing lockup
Old 01-14-2015, 12:15 AM
1991Ranger2wd's Avatar
1991Ranger2wd
1991Ranger2wd is offline
Hello,
Has anyone else experience their A4LD transmission NOT RELEASING LOCKUP in both 3rd and 4th? My 1991 Ranger 4.0 will get into lockup sooner than normal(comparing the recent past), and would stay in lockup long enough to make the engine shudder when I slow down to come to a stop. (much like holding 4th gear without putting in the clutch when you approach a stop.
It doesn't die out and does shift into the proper gear but only after the RPMs dive down to probably 400 and the vehicle shudders a bit.
Received and replaced the throttle position sensor today, looking to do the vacuum modulator this w/e. Any other possibilities? Suggestions?
Old 09-03-2015, 05:23 PM
silverranger1992's Avatar
silverranger1992
silverranger1992 is offline
Exact same problem...
Originally Posted by 1991Ranger2wd
Hello,
I'm currently experiencing the exact same problem with my 1992 Ranger 4.0. Were you able to get any useful information or solution?
tmryan362
1983 - 2012 Ranger & B-Series
06-04-2022 06:43 PM
AderisKD
01-05-2017 08:53 PM
nickp112
01-18-2015 08:11 PM
stahl1911
07-29-2012 08:13 PM
Quick Reply: A4LD not releasing lockup
