Vacuum booster arm adjustment
Old 07-20-2003, 11:54 PM
youngguy's Avatar
youngguy
youngguy is offline
I recently replaced the vacuum booster on my 1985 Ford F-250 (460 c.i.d.) and adjusted the arm that enters the master cylinder to the specs that my Ford shop manual specifies. After doing so, I took the truck for a ride and the brake pedal seemed to be very soft and the brakes did not operate as well as I would like. I pulled the master cylinder off and adjusted the arm out a couple of turns and this showed a dramatic improvement. My question is, should I leave this as is or put the arm back to the specs the manual specifies. The manual instructed me to build a cardboard template to check this measurement and it seems like there should be a better way as there is only a span of .015 inches to work with according to my manual. Any suggestions would be appreciated!!
Old 07-21-2003, 08:29 AM
steve83's Avatar
steve83
steve83 is offline
If it works, I'd leave it. I've swapped parts all over my truck, and I've never even checked that. Right now, I have a used '93 booster and a reman '94 MC on my '83 and they work great (except that I have 2 proportioning valves right now).
Old 07-21-2003, 04:30 PM
youngguy's Avatar
youngguy
youngguy is offline
Thanks again Steve83,
Your advice is invaluable!
sonny1965
03-22-2021 02:00 PM
aerocolorado
Aerostar
08-20-2013 06:06 PM
abyars111
03-25-2013 11:02 AM
f100jim
07-16-2007 05:43 PM
73FOMO
11-13-2005 01:04 PM
Quick Reply: Vacuum booster arm adjustment
