3% Oil Dilution and Poor Fuel Economy
So, my truck as about 11,200 miles on it. I just pulled a Blackstone report on the truck with the last oil change and saw that I have 3% oil dilution. As well, this truck gets between 1.5 and 2 mpg less than my 2011 F-350.
Any thoughts here? I've see highway fuel economy as low as 13.5 mpg as an average. As well, this truck religiously says I've used less fuel than I pump into the tank at each fuel up. I have all of the fuel records in a notebook.
A new Duramax will cost me 7 grand to switch, but I'm tired of getting mileage that a gasser truck would get, but don't know what to do.
Engine Hours: 274
Idle Hours: 39
Mileage: 11,200
Over half this oil change was a trip to CO Springs and back. The rest was in / around Las Vegas area with very little city driving. I commute in my car mostly and the truck sits.
Regen between 2-3 times per tank....its easily less than every 200 miles. Exhaust pipe is still shinny Chrome.
Idle Hours: 39
Mileage: 11,200
I don't know much about the Duramax mileage but if the GM is known for great mileage and makes you happy, 7 grand may be another year of payments. Not too much if the Ford is not making you happy and it cannot be fixed by your dealer.
Yeah, its a year of payments. Its not the end of the world, but I'd rather keep 7k in my pocket and make Ford fix my truck. I still very much like this truck, but I don't know how to convince Ford to take it seriously. Also, who's to say I buy that Denali and then have problems with it?
I can't say I've exhausted all of my Ford options. If I had, then I'd just switch. I haven't contacted Crystal yet either, but then again, I don't know if I have enough information outside of my log book of fuel stops and this oil report. I do know that at the last oil change, they drove my truck 20 miles with a computer hooked up and got 17.0 according to their printout. I will also say this truck hasn't averaged 17.0 on the highway in a long long time, but I do know that my 2011 would easily get over 18-19 out here driving the same way.
No Crystal ball....
No Crystal ball....
keep a log and show them fuel receipts and the log book.
What about boost? Higher than normal based upon the route you drive?
I had that happen on my 08. I told them my fuel ecomony was down and I was pushing higher boost than normal.
My high pressure turbo was out of spec so they replaced it.
Keep the ideas coming! I need to be talked off the ledge!
Hubs are not locked and haven't been. 4x4 system seems to engage / disengage properly when I've used it. The tires are the stock 20 inch rims.
Nothing is aftermarket on this truck outside of new shocks and a steering stabilizer. Heck, even the Tonneau cover says Ford on it !
I do run the Ford Cetane booster in the truck too. No aftermarket stuff there either (forgot to mention that).
