Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2005 ford escape transmission fluid change
Old 01-06-2015, 05:18 PM
Drew2128's Avatar
Drew2128
Drew2128 is offline
So I am changing my transmission fluid tomorrow and was wondering a few things.
1. I noticed some people pull off the transmission hose to the inlet and keep draining that until its clear. For a drain and fill do you do it like that or just pull the plug and refill?
2. When youre filling it back up you just measure how much you taken out and then fill the rest by the dipstick? Anything else i should know?
3. Since I havent changed my transmission fluid in 60,000 miles. I wanted to do a drain and fill. I was thinking I needed to drain and fill it 3 time to catch up to maintenance. How often would you do it to get it clear? Drain and fill then drive it for a week then drain and fill? Or do it all in one day?
Old 01-07-2015, 05:36 AM
jbtecnico1's Avatar
jbtecnico1
jbtecnico1 is offline
welcome, use Search tool
Welcome to FTE...this is an invaluable tool for me as a DIY'r with three Ford rides...
Since you are new, use the "Search This Forum" tool within the Escape Forum to look for past posts. There are already plenty of Replies to your question... Have fun, research is the best way to educate yourself with the wealth of information in this Forum.
Here is a snapshot of the Search Tool, look to the right of the image...
Old 01-07-2015, 12:06 PM
Drew2128's Avatar
Drew2128
Drew2128 is offline
I did read alot of them, they didn't necessarily answer al my questions. Thanks
I think this is the drain plug, but I want to be 100% sure. I know the plug to the right in for the oil. This is a FWD car so it couldnt be anything else right?
I attached a link for the photo since i dont see a way to show a photo.
The bolt that is clearest on the left is my guess on the transmission drain plug. The bolt that is blurry to the right of the oil filter is for the oil. I just want to make sure that the square bolt to the right is the transmission drain plug
Looking at this picture the front of the car is straight and the drive side door is to the left of this pic.
http://prntscr.com/5pmqdq
Old 01-07-2015, 03:12 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The plug that your 3/8" drive fits is the CD4E drain plug.
Old 01-07-2015, 03:51 PM
Drew2128's Avatar
Drew2128
Drew2128 is offline
Thank you, I am done. IT was much easier than I thought
akblackfoot
07-30-2016 06:25 AM
trackfactory
1997-2006 Expedition & Navigator
05-29-2011 04:33 PM
amaksut
1999 to 2016 Super Duty
02-01-2009 03:08 PM
Mark-I6
04-11-2006 10:59 PM
streetpreacher
Aerostar
10-21-2004 05:38 PM
Quick Reply: 2005 ford escape transmission fluid change
