2015 ANNUAL, B.S. AND EVERYTHING ELSE!!
#166
Also lets see if we can get a window seat so we can watch the little metal birds.
BTW there are a few larger one at Thun also.
Sean
#167
Received 3,564 Likes
on
#168
#169
Was a long weekend, two 10hr days of pressure washing, one large 2 story house, 2 2 story condos, an ornate/large entryway and a Boat House.
Also booked out for the next few weekends.
Sunday I lost the Alt belt off my truck on the way to the first condo, then my high pressure hose blew, was all about "Takes money to make money", only $20 profit Sunday but better than nothing.
#170
And now you've got a new belt and hose. Progress! I've purchased the gasket set and ground cables for my truck. In the morning when I go home I'll probably have the intake off and start the clean up relatively quickly. I need to buy rags, all mine have oil and grime on them.
I don't have a vacuum gauge for tuning, I forgot to grab one. But, when I get the intake back on, I'll have to let the RTV set for a few hours, I can use that time to go get the gauge. I'd like to learn to use it efficiently so I can get better at tuning. I can get my vehicles to run, just nor very well.
#171
While you cleaning around the intake ports some blue painters tape
can help to keep the crap from falling in. I know it won't help you
right now but I now have an extra small shop vac. The larger Sears
one is going to John. But if you want to talk I would be happy to listen.
RedNeck sneaky way to find an intake leak. Propane torch and snuff the
flame. Set it on low and go around all the places you think might be leaking.
When you find one the RPM will go up and sometimes the idle smooths out.
You don't need a bunch just a little will do the trick.
Sean
Sean
#172
#173
If the happen to be the red ones. DO NOT WASH WITH ANYTHING ELSE.
The first wash should be in hot water to help set the dye. It has a habit
of not being color fast and leaves the fabric. I have some very nice "Pink" white towels.
I don't count them as safe till after about the 5th wash or a bit more.
Sean
Sean
#174
Only ever wash shop rags at a laundry mat, unless you want to kill your washing machine...
Buying a $110 High Pressure hose for the pressure washer REALLY ate into the profit for the day. But it is a higher quality, longer length and larger diameter than the one that blew so I won't complain too much.
Redneck way? Propane is the Harley Tech method for Intake Leaks, their fancy tool is a propane bottle with a small regulator, 3' flex hose and a 1/16" metal tube for finding/pinpointing leaks.
#175
On my VW bug I used to use a handheld plumbing torch with a snuffed flame.
Silly single port engines used to use a crush washer to seal the intake to the
port on the head. Sometime they would run like a pig. You take the propane and
blow it around and if it can back to smooth you know what to fix.
Sean
Sean
#179
In the end, I forgot to get rags.. Needless to say, I owe my mom a few rolls of paper towels .
I cleaned up all the crap I left behind, that's the last time I try to use RTV on everything to seal it. I feel mor confident about this valley pan and the way it fit. So far I snugged the bolts and I'm letting the new RTV cure. When I get home I'll torque them to spec and see about starting it. It went relatively well in the end, but I'm still a bit worried. I really want this to work.
#180
OOPS
Unless the instructions say to let cure before torquing you are going to leak again.
That stuff is squishy and will give you a false torque.
BTW that stuff will setup without any air once it has started to skin over in
about 15 minutes or so. But don't wait too long. Better to stick on when wet
and torque it right away than to wait.
Sean
Sean
