Wanna see pics ON TRUCK of Spyder vs Recon Headlights
on
HIDs emit their light out the sides as does the LED. Most Halogen lights have caps on the ends and also emit their light out the sides.
From what I have read, Projector lights also have reflectors but use a lense to put a tighter focus on the light coming off of the reflectors.
Like this picture below::
Not entirely sure I am buying this...
Recons. Look cool, low beam light is crap. Brights are good. I have HID's in my low beam that are a dual beam H13 kit. The HID bulb is both a low beam and a high beam that comes on when the brights are activated. I also have the standard halogen silver stars that come on as well for high beams. I love the look, but hate the low beam output. I would recommend a larger projector housing installed in the stock housing if you are wanting better light output.
Black Flame Customs is the way to go for light output. They re-fit your current housings with HID projectors. It's a labor intensive process so it's expensive. However, it's the only way to go if you really want more light from the stock location. I opted for a Rigid light bar instead. I can now help land planes if the power goes out at the airport...LOL...
If you dig into the site, you will find that they will retrofit yours for around $275 labor + whatever options you want or sell you replacements for $1250 + upgrades. My guess is that you will not save much by having them retro your existing assemblies. They quote you by the job. It's not a very easy site to navigate(HID Projector Retrofits, Custom Headlight Packages & HID Projector Conversion Service | BlackFlameCustoms.com) and way more then I can spend.
#29
Irelands child is right about their site. I contacted them directly when I was considering this. I can't remember the quote but it was highly variable based on options chosen. I told them to do my quote based on the 100% best projectors and best ballasts reusing my existing housings to save money. I believe it was the LS460 projectors and Morimoto XB55 ballasts. I opted out of smoke treatment, halos, and eyebrow LED's to save money. Plus, I wanted max light as opposed to looking like something from the fast and the furious. They get all their parts from The Retrofit Source so if you were highly mechanically inclined, you could order the parts direct and do it yourself. It takes a lot of cutting, leveling, and reassembling though and I personally wouldn't dream of it.
