My Bump is a Workin' Son Of A Gun!!!
on
thought id start a little thread here....
i towed this car for a buddy of mine a few days ago. 3,000lb trailer and 3,000lb car = roughly 6,000lbs in tow. i had a few hundred pounds of stuff in the bed too.
took her 30 miles down the highway doing 60-65 no problem.
about 6,000lbs on the hitch
off-loading
off-loading
The following users liked this post:
Its no doubt that the Ford does what it was designed to do. Towing is a severe situation for any vehicle and all the parts involved need to work. The includes engine, trans, rear end, mirrors, electrical, and of course brakes.
John
on
Going to Payson. Down the pass at Mt. Ord. that was still with the C4, I had it in 3rd gear and was coasting down at 70MPH! It got hairy once. I burned the brakes a couple times just trying to slow down to 60.
on
heres another load. this trip didnt go so well however
about 70 tires
highway 87, mile post 215, 35 miles south of Payson, AZ. 55 miles from home.
pushrod said "F-this! im outta here!"
its a mountainous road, i was pulling up the grade at 3200RPM when all of a sudden, the engine lost power and started ticking bad. oil pressure was down and vacuum was erratic. pulled over and figured it was coming from the passenger side. shut it off, pulled VC and found #1 exhaust pushrod had revealed its secret identity of a boomerang.... called back home and told the Ol' man i needed a pushrod. 3 hours later, he showed up and i had it back on the road pulling, finished the last 50 miles of haul up the hill, unloaded and drove 105 miles back home. ran normal.
however, i did order a set of 3/8 diameter, .080" wall, chromoly 1-piece pushrods from COMP Cams. should be here monday. then i shouldnt ever have another pushrod failure...
about 70 tires
