4.9 efi stops running when i hit bumpy roads
OK here's some history. I swapped a 4.9 out of a f150 into a 95 bronco. I've been drive it for about a month now with little to no problems. Until now.
I was driving down the interstate at about 70 MPH when it just shut down. I was in 5th gear the engine was turning but not running. I held the clutch in and gave it gas a nothing. Tried starting it and the starter just grinded like the motor was still turning. I put it in 4th gear dumped the clutch and it took right off. The after that every time I hit a bump it would die out again but not at bad. then it got the where it would just sputter when I hit a bump.
I'm inclined to think its something in the fuel system but it's got a new tank, fuel pump and fuel filter any help would be great
Doubter123
06-21-2013 08:13 PM
JetBlackBronco
1978 - 1996 Big Bronco
01-06-2006 06:16 PM
