why nitrogen inflated tires?
Nitrogen seeps out of the tire a bit less than compressed air . It also runs cooler . As far as I am concerned ... A bit of a scam though . Tires still need to be checked regularly . Just because they " fill " with nitrogen , they are not maintenance free . I also have doubts about the nitrogen content at many places . I have a local tire shop that was scamming buyers .
Only three reasons for nitrogen inflation:
1. You have a race car.
2. You have too much money.
3. You believe the marketing hype. 'Cause that's all it is. There is absolutely no benefit unless you refuse to check and properly maintain your tire pressures. If that's the case your tires will go flat a *little* bit slower.
But with rudimentary compressor maintence you'll be fine.
There are many reasons not to use nitrogen. The cost and the availability are the 2 biggest. If you keep your tires longer nitrogen can lead to dry rotting faster because it doesn't hold moisture. Air actually forces moisture through the treads of the tire which MAY help keep the rubber from drying out.
on
A bottle of nitrogen is cheap, I have one strapped into my tool box, it's alot more stable than air, depending on were your filling your tires. Some shop compressor's have auto oilers, you dont want that in your tires, some shops dont maintain there compressors and are filled with water, and you dont have to worry about going out on a freezing morning to low tires. I use it for everything, I have a blow gun attachment, it runs air tools. I can fill all 4 of my 35" tires after airing down to run on the beach. I dont know what I would do without it now.
