Partially stripping sensors 98 302
Old 12-18-2014, 09:35 AM
yonu's Avatar
yonu
yonu is offline
ok all I have a dumb question I am just picked up a 302 from a 98 explorer with about 60k miles on it to replace the carbed 302 in my boat. With it being a 1998 engine what sensors can I safely remove and have the engine run. I have done it with a 1989 302 in my pickup but never a OBDII engine.
oh and before it comes up the boat is fresh water cooled so no salt-water will be going through the engine.
Thanks,
Yonu
Old 12-18-2014, 09:49 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Are you swapping the fuel injection as well or is it going to stay carb?
Old 12-18-2014, 10:03 AM
yonu's Avatar
yonu
yonu is offline
Nope I am swapping over the efi as well which is the reason I was unsure of what sensors are absolutely required because of it being OBDII
Old 12-18-2014, 10:08 AM
MisterCMK's Avatar
MisterCMK
Leave all of them alone.
Sent from my Telegraph using IB AutoGroup
Old 12-18-2014, 10:10 AM
yonu's Avatar
yonu
yonu is offline
What about the stuff that can't be swaped over like the exaust sensors?
yonu
Old 12-18-2014, 10:22 AM
MisterCMK's Avatar
MisterCMK
yonu
You will need the front two for sure. The rears will need to be turned off with a tune or just deal with a code for them. You could get some O2 simulators and add extra bungs in the exhaust but those seem to be hit or miss.
Old 12-20-2014, 05:16 PM
Conanski's Avatar
Conanski
Conanski is offline
You can't put an automotive EFI system in a boat and that's mainly because of the O2 sensors. You can use this motor no problem but you will have to strip it to the bare longblock and install all the standard marine intake and exhaust components.
Old 12-20-2014, 05:49 PM
MisterCMK's Avatar
MisterCMK
With some custom tuning I don't see any reason why it couldn't be done. Just lock the thing into open loop and make sure your fuel tables are dialed in. No feedback from O2 sensors required.
Old 12-20-2014, 05:58 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Are you familiar with inboard exaust manifolds ????
Old 12-20-2014, 07:26 PM
MisterCMK's Avatar
MisterCMK
You wouldn't need the O2 sensors.....
And no, I am not but I would imagine putting O2 sensors in would not be possible. That is why I am suggesting to just tune it to run in open loop.
Old 12-20-2014, 08:03 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
It would be unreliable , at best . A marine engine operates under different load conditions than a road engine .
Old 12-20-2014, 08:11 PM
MisterCMK's Avatar
MisterCMK
Hence the tune required.
How would it be unreliable? Have you ever tuned a vehicle?
Sent from my mind thanks to the Internet and an app.
Old 12-20-2014, 08:26 PM
Conanski's Avatar
Conanski
Conanski is offline
I'd agree with that but I got the impression the OP was wanting to utilize the Explorer system as is which besides being a giant PIA for multiple reasons(no PATS, no auto trans inputs, no speed input) would just result in a crippled EFI system running pig rich which means he may as well put a carb on it.
Old 12-20-2014, 08:35 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I Have not " tuned " a vehicle . I Have repaired many due to faulty " tuning " Most tuners I see , in my area , are problematic at best . Many issues are likely compounded by improper add on components . Too many people reading on line posts by some jackleg ....
Old 12-20-2014, 08:53 PM
MisterCMK's Avatar
MisterCMK
So you are unaware that a vehicle with efi cab be tuned to run just fine without o2 sensors.
Quick Reply: Partially stripping sensors 98 302
