8.8 swap
12-17-2014, 06:29 AM
8.8 swap
Just picked up a 97 f150 will the 8.8 out of it be the same as my 96 f150.
Its 3.55 gearing same as mine. Thanks
12-17-2014, 06:34 AM
Wheel bolt pattern is different and I don't know if the axle shafts are interchangeable. Wondered about that myself.
12-17-2014, 02:25 PM
I just tried one of the wheels and it bolts on my 96. So the bolt pattern is the same
12-17-2014, 03:51 PM
Quote:
Originally Posted by
deljac
The bolt pattern is darn close, but there are differences:
Ford F-150 Bolt Pattern Guide Reference BoltPatternGuide.net
1954-1996 F150s use a 5 x 5.5" (139.7MM) pattern
1997 to 2003/4 F150s use a 5 x 135MM pattern.
I would not swap rims on those two different generation 8.8" axles.
12-17-2014, 06:46 PM
Ya I tried the spare and I worked but none of the others do. So I'm guessing its from an older ford.
Apo stolic
11-04-2018 04:12 PM
taylorbickett5
09-16-2014 03:44 PM
Bovaloe
04-27-2011 05:19 PM
37 Ford guy
07-23-2009 06:39 AM
slow_v6_stang
02-01-2006 07:40 PM
