I think i blew it
on
I'm still in shock, but I think I just blew a head gasket on my engine. I was out hot Rodding around ( semi-normal) but this time I wrapped it up to about 5400-5500 rpm. I felt/heard something right at that second. But at that same time I shifted so it didn't do much. But a few minutes later I saw the temp gauge starting to rise. Then I seen smoke/steam under the hood. I got home a mile later and there's steam coming up from the passenger side valve cover. And the passenger tailpipe is spitting coolant.. So, give me the worst. I'm ready for it.
High RPMs is not what blows head gaskets. Something else happened. Is it running on 8 cylinders? Check coolant level. Check for leaks. Check for presence of oil and/or exhaust in the cooling system...
Pull the plugs and see if any are steam-cleaned. Run compression test on the suspected cylinder.
on
High RPMs is not what blows head gaskets. Something else happened. Is it running on 8 cylinders? Check coolant level. Check for leaks. Check for presence of oil and/or exhaust in the cooling system... Pull the plugs and see if any are steam-cleaned. Run compression test on the suspected cylinder.
Hydraulic lifters? Could have floated a valve and had some inadvertent contact. I've been meaning to get one of those bore scopes from HF when they go on sale so I can peek in the spark plug hole. Three possibilities because you are seeing coolant:
1. Head gasket
2. Head cracked
3. Block cracked
What's the bore currently on your block?
1. Head gasket
2. Head cracked
3. Block cracked
