Alternator issue upgrade cause of AC cab?
1G has a regulator on the fender. 2G has an internal regulator but still has an external fan. 3G has an internal regulator and fan.
Many alternators have the rating stamped on them somewhere. But, if it has been rebuilt the stamping may not be correct. So, I don't know that you really can tell.
He says 'the alternator has 3 wires on the back'.
'A Red wire with a nut'.
That is 1G for sure...
If the original truck was a stripper, he likely has the 40A alternator.
If switching from an idiot light dash to one with gauges, the 1G regulator plug changes too.
At that point, I would opt for a self contained 3G.
The 95A will fit fine and have enough power for a 'stockish' truck.
It helps understand which configuration your regulator was wired.
I'd imagine any XL/T would have gauges.
The power window motors are a pretty big draw, but you are only going to operate them for a few seconds.
The battery can handle that.
Having the A/C blower running is no different than the heater in winter, except for the power used to engage the clutch.
I'm not sure how much those draw.
You dispose of the tin can regulator.
The 3G alternator only needs the ltGrn/red (hot in start & run) exciter wire.
A large gauge charge cable with an inline fuse is connected to the battery+ side of your fender mounted starter relay.
The 2&3G three wire regulator plug is connected to the ltGrn/red power wire, the white/black stator wire is looped to the single stator connection on the back of the alternator and the yellow/white 'sense' wire is connected to the output stud along with the charge cable.
Does your new cab have an ammeter?
Probably best to convert that to a voltmeter.
They can barely handle 65A, let alone 95 or 130...
