Constant power for LED strip lights in bed
It was luckily very simple. I used some electrical fish pulls to pull a red (+) and negative (-) wire through flexible conduit. I ran that from my engine compartment back to under my bed & up to the stake pocket where I mounted the switch. Take a look at the wiring diagram in the first post.
When i first installed it, the light was on all the time. For whatever reason, now it only comes on when the light is on (which is nice so that it doesnt drain the battery, although i'm sure it would take a LONG time of the truck sitting for that to happen)
Here's what i ended up using. You can cut in half and both ends have factory wire leads so you essentially end up with two 8' strips which is plenty for the bed. Just seal the ends with silicone. $20 does your entire bed (plus cost of wire & switch which are cheap).
These have a nice warm yellow color that match most of the factory lighting so you dont end up looking like a 3/4 ton "import" that you'd otherwise have with the white/blue lights out on the market.
Saw a new F150 and the inside bed LED lights caught my attention. They turn on with a waterproof flush mounted pushbutton switch in the bed. The LED lights are also flush mounted in the front of the BED on the sides (by the tailgate) The switch also turns on the cargo CHM light so you don't have to go into the truck to turn that light on anymore.
Kinda thinking of looking at a way to adapt that to a SUper Duty. And it worked with the truck off and no key in the truck. (New F150s are push button start, no ignition per se)
And it is on a timer... So I think that solution fits ALL of our needs. I am happy because you can't leave it on and everyone is happy because it works without the truck running or key in it.
Thanks for the feedback. Based on feedback, I'll revise my plan:
-Ground picked up at bed rather than all the way at battery
-Ground for lighted switch required
-Keep the fuse (its only $3 and 2 mins to install)
I'm also going to add a short section of LED's and a rocker switch under the truck near the oil pan and under the hood. Should make changing the oil a little more pleasant and worth an hour of install time over the life of the truck.
Any other ideas for locations to add them? They're pretty cheap and very easy to install.
My truck had a factory wire terminated on both sides of the truck for added step lights. I believe all 6.7 lariats, king ranch & platinum came with it. It's located near the parking brake cable on the frame with a plastic cover over the end. Same location on the passenger side of the truck.
Nice lighting set up. How did you attach the LED strip to the under the bed rail? Velco or double sided 1/2" tape? I was thinking going with 4 foot LED bars but the flexible LED strip looks like a better option. Strangely enough, I thought of doing bed lighting. I just never got back to the idea and forgot about it. My friend suggested it too. Thanks for posting up. It rekindled an idea from the past.
Good job!
Good job!
Good job!
Good job!
#28
Very nice job on the bed lights. I was actually thinking of doing something like this when I get my truck (on order) I thought I would be the only one with them lol. I think they are good idea and with them under the bed rail they are out of the way and not blinding as if they were mounted on a headache rack.
#29
thewheelman
2015 - 2020 F150
17
02-02-2017 12:44 AM
