AOD output shaft play
With the prop shaft off, the end of the output shaft on my AOD gearbox can easily be moved from side to side, over an eighth inch relative to the casing. I would appreciate it if anyone can tell me if this is normal or what I should be doing to fix it. Thanks.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
dsc
01-14-2011 02:59 PM
fiittllc
11-11-2008 12:49 PM
460
06-23-2005 05:52 PM
Jimbare
07-13-2003 02:36 AM
