55mph turning 4000rpms?
I have a 75 f100 4x4 that not to long a go I turned my 360 into a 390. Engine: holley 750 vac. secondaries, performer intake, stock heads, 360 pistons, CR: 9.3-9.5 to 1, performer plus cam, Sanderson ff427 headers. The front chunks tag reads 3.50 gears and the door tag says it came with 3.50 gears so I'm assuming that's what it is unless they have been changed, which the PO said it had been swapped to 3.90 gears. That being said he's lied about the truck claiming the old 360 was of course a 390 which it wasnt. The truck has always been sounded like it was hollerin at 55 to 60 but I just installed a tach and it's reading around 800-1000 idling and 4000 at around 55-60 cruising down the highway. The Tach was gave to me from a member off FTE, it has no switch to change it from 4 to 6 to 8 cylinder. Anyone have any guesses? That seems like way to many rpms.
First, try to determine what the actual gear ratio is
If both front and back check out as the same ratio, and the ratio matches the tags, then another thing to look at would be if your clutch or torque converter is slipping excessively
Also, some tachs use switches, some use the clipping/not clipping of a certain wire on the back or under a cover to adapt the signal to different cylinder counts.
I'll check and see for sure the gear ratio and let you you know. It's a straight shift but when I dropped the motor back in the clutch didn't need to be changed it looked good, also the truck shifts fine. On the tach, I grounded the ground, put 2 wires behind one of my fuses then tied the last wire in to the wire running out the coil that says Tach.
How to find out your diff gear ratio - YouTube
