Best place to get a rebuild kit? I want to do the obvious pinion and carrier bearings shims. Seals their gears are good I looked at them when I had it apart and there is no chipping gougespecially or weird wear patterns.
If you're looking to get the truck semi-reliable with the absolute lowest investment, then fine. But if I had bearings that messed up there's no way I'd put the same gears back in. Gears aren't that expensive compared to the effort to replace them. While it's apart I'd do it right.
Nothing special I hear ya on the gears but lime I said they have no funky wear patterns or hot spots or weird mess patterns. Gears will usually tell you when they need to be replaced.
