axle question
Received 3,186 Likes
on
on
on
Do you tow a lot? With only pulling 10K it should be like it ain't back there unless you pull a lot of hills. If you pull lots of hill and tow a lot, 4.33 with those tires hands down.
My son runs 4.56 with 35 tires and 6 inch lift and with his 5R110, 6.0L, he pull same RPM's as I do with the 4R100 and 4.10 rear axle in my dually. Hope that helps.
Not sure what gears it has yet. I haven't looked at it.
My truck was doing good to hold 50 mph towing the camper. The tranny stayed over 200*
Since then I have fused the coolers and completely drained the tranny and put all new fluid and filter. It still drives good. Shifts the same as before.
fstonracday
02-22-2004 11:05 PM
Clay911
07-04-2003 05:31 PM
