New Puter
Dick
I feel your pain.
Last spring my wife got me a new laptop. This thing is loaded with a touchscreen and windows 8. I was just starting to get used to things and figure out how to get around when I ended up downloading something I shouldn't have.
After I did a removal of the unwanted programs my whole "sumbeach" was different. I spent 3 days messing around with it before pulling the plug and resetting this POS back to factory specs.
So, now everything is back to normal....well, back to the way it was when I got it new. I've been busy trying to reload some of my programs and files and get things back to the way they were before I screwed it all up.
For the record...I'm not a big fan of windows 8
Bobby
I feel your pain.
Bobby
I still haven't found too many people that like windows 8. Two things you can do to change it some.
One is install classic shell. It will make the interface more like windows 7.
Classic Shell - Start menu and other Windows enhancements
Two is if you need more speed use the ultimate windows tweaker, it has all of the hidden setting in a easy to use interface. Just make sure you hit apply before each tab, you don't have to even mess with this if you don't like changing settings. So far the quickest shut down time we have had with windows 8 was less than 10 seconds.
http://www.thewindowsclub.com/ultima...er-3-windows-8
If you have some stuff starting up when windows starts and you don't want it I can walk you though that as well to turn them off.
(I am regular on the Panasonic Toughbook forums)
Thanks for the offer and the tips.
I typically go to the classic desktop and then work from there. I do use the windows 8 apps now and again and I had it set up where you could run the mouse pointer up towards the upper right hand corner and the "minimize, restore down, and close" buttons would show up. When I reset back to factory that no longer works.
When I'm done with a Windows app I want to close it, I don't want it hanging around in the background.
I know that you can go over to left side of the screen and it will show you what is open and then you can right click and close them, but that's a pain.
any ideas?
Thanks
Bobby
any ideas?
Thanks
Bobby
What made it harder for me, was that they didn't send any instructions with it. Good luck Dick, I've had Window 8 for a while now, and I still forget how to do things I have done B4, like reset the system to the last date it worked correctly. IMPO user friendliness, is not its strongest suite.
Thanks for the tip guys - I've been messing with computers since the mid 80's, 1 big mainframe on Wright Patterson AFB serving ten thousand folks, It would crash 7/8 times a day
I started Windows with V3 even the 20 disk windows change was easier -
This time I'm switching from Vista to 8.1 and the new IE screwed up
any ideas?
Thanks
Bobby
any ideas?
Thanks
Bobby
I too have been messing with computers since the early 80s, before IBM introduced the "PC". My first "real" computer had dual processors and ran either MS/DOS or CPm. I finally graduated to Windows for work.
I got a new laptop when I retired and I'm getting used to Windows 8.1 and the touch screen. I never use the Home screen, unless I hit it by accident. I do like the fact that I can get rid of it by sliding down the screen with the pointer or finger.
Good luck with your new puter.
Sounds like when you reset back to factory specs, you lost the 8.1 update. That's a feature that's only in that update. You'll have to go on the Microsoft site and re-download it. In the mean time, if you click at the very top of the window and drag the whole thing down until it disappears moving down, that also exits out of the app. If you have touch screen you can do that same thing with your finger.
Thanks, I'll check for updates and go from there
Bobby
