Lets find Mr. and Mrs. Apocalypse their future new to them Excursion
#106
Anyway hope that helps!
#107
After years of research, countless hours on the web, painstakingly reviewing each word, we finally have that $5,000 .... err, mile Excurion for the Apoc family! (Needs some work on the roof, but has the 6oh!).
Other Makes Ultra American Assassin Limited | eBay
I knew the guy who built it, went by Moffat. He built it for his kids and grandkids but they just had no interest. Here is a video of his Excursion running Moab.
http://m.youtube.com/watch?v=jg7scz7B6Wg
#108
The SCA forms a protective layer (like a blanket) on the surface of the metal. This protective layer is constantly being worn off due to cavitation created by the diesel engine (the protective layer take the hit to keep the metal from being damaged) and as it gets worn off, the silicate will form extremely small particles that fall out of the coolant.
This silicate fall out will eventually damage and clog the oil cooler on a 6.0L engine which can eventually cause complete engine failure if it isn't caught and addressed.
The Ford Gold (a hybrid OAT coolant) and a true Heavy Duty Organic Acid Technology Extended Life Coolant (HD OAT ELC, or ELC for short) protects the metal surface differently.
H-OAT coolant (a Hybrid OAT) still has silicate in it, but much less than the traditional "green" coolant, and it isn't a true HD ELC, hence the hybrid moniker.
A true HD ELC is completely silicate free and provides better heat protection along with a superior cavitation protection.
my 2005 came with ford gold from factory it could never be mixed.
Since your a retired mechanic you would probably understand that while most garages do a flush there is always some old coolant left behind.
Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
if the green and gold coolants mix at all it turns to gel ( based on the different chemicals used).
You can mix ELC with Gold, ELC with the "green", or Gold with the "green" and nothing adverse will happen, like goop or mud being created. All that will happen is, whichever coolant is the lesser of the two that are mixed, the coolant will basically become that coolant. So if you have an engine full of ELC and you put too much "green" in it, you will have to treat your coolant like it is a traditional "green" coolant since you will have rendered the ELC ineffective.
As Stewart mentioned some go with the ELC or the red stuff it suppose to be better than the gold which is rated for 100k
I prefer the Chevron Delo OAT ELC. It's good for 8 years or 750k miles. With an extender it's good for 10 years/1 million miles.
I unlike a few diehard 6.0ers I am staying with the ford gold because the red is not in spec with Ford
Back in '99 when International changed certain things in the 7.3L engine making ELC compatible with the PSD, they switched over to ELC for all the international 7.3L PSD engines. The only reason Ford didn't was uniformity for their other engines.
Ford has never stated ELC is not compatible with the PSD engine. They can't, since the engine was made by International and International is the one that spec'd it to work properly with an OAT ELC. Ford simply filled and recommended Ford Gold because it was simpler and cheaper.
For anyone wanting more info on a HD ELC, please click the link above as I've included just about all the info from Gooch, as well as just about all the information I found when I researched the subject.
Stewart
#109
Stewart do you ever sleep? LOL. I am waiting to board a plane, what is your excuse?
I think mixing a silicate free elc (SFE) with ford gold isn't a great thing. The SFE uses a different chemical reaction to prevent cavitation, and the presence of silicates interferes. There is a process to change from gold to a SFE which is posted elsewhere on FTE.
Edit: after sipping coffee I read ALL of your post, you already said what I tried to add..
#110
Conventional "green" coolant typically use a phosphate/silicate mix as the main components in their inhibitor system. Conventional inhibitors like silicates and phosphates work by forming a protective blanket that actually insulates the metals from the coolant. These inhibitors can be characterized chemically as inorganic oxides (silicates, phosphates, borates, etc.). Because these inhibitor systems are depleted by forming a protective layer, conventional green coolants need to be changed at regular intervals.
Conventional coolants containing silicates degrade primarily due to rapid inhibitor depletion. This is because silicates lay down protective layers as part of their protection mechanism. That means the SCA level must be tested on a regular basis and added as necessary to ensure against cavitation.
Heavy Duty OAT ELC's use carboxylates as an inhibitor to prevent cavitation. Carboxylates actually interact with the metal to protect from cavitation. It does not form a layer that will deplete or wear away over time.
Ford started using this silicated H-OAT formula starting with the 2002 model year trucks, traditionally gold in color, equivalent to the Zerex G-05 coolant.
If you are, then the process for back-flushing a 7.3L engine to prep it for ELC is detailed in the link I posted in my above post.
Stewart
#112
#113
#114
on
#117
OK, here is the one I sent you: Click Here
If you are still looking for a 4x4 V10, then this might be one for you.
I still think you just need to turn your 2wd V8 into a hair on fire supercharged highway cruise missile!
#118
#119
