WTB: 351W/C6 Separator/Spacer Plate
Category: Drivetrain
Price: $1
Private or Vendor Listing: Private Listing
Item Condition: TX
Engine: Part suitable for gas truck
Please let me know what you got as well as any pictures.
Thanks in advance
spacers
I have 3 different spacers but not sure which one will fit your app. any way to identify which one of these will fit? there are no identification marks on them one is an aluminum spacer.
Hi Roger,
I am not certain on how to identify if they are correct. I do know that NumberDummy said that it should be the same for C4/C6/FMX. Below was his response in my post if it helps. Is there a part number on the spacers anywhere?
D2TZ-7007-A (replaced D0AZ-7007-A .. Engine rear plate-same C4/C6 FMX (see car parts catalog apps) / Also same: 1969/79 F100/150 & Econoline 240/300/302 & 1975/79 E100/350 351W
I did find one from NPD that uses the part number NumberDummy gave so it may look like the one below but again not 100% sure.
I have an aluminum spacer which is marked DE CA. It's off a 1980 Mercury Monarch. It is the same size and pattern as a steel spacer I have. It's likely the one you are looking for. Bolt spacing between the 2 bottom bolts are about 12-1/2inches apart. Measure the bottom right starter hole to the bottom left bolt hole and it should be about 12-1/2" apart
I couldn't find anything on if the 80 monarch would be the same but it sure looks similar.
I did measure from the lower start bolt hole to the hole straight across from it on the other side of the trans. I measured 12 7/16 from center to center. The National Parts Depot product does not have the two humps on each side of the center hole but another plate I found with the D2TZ-7007-A part number did. So I assume the NPD pic is probably generic.
You wouldn't happen to have the lower inspection plate for it would you?
Thanks for the info and pic as well.
Mike
Mike
FordFETruck
07-05-2012 03:21 PM
Dieselman729
12-24-2011 09:50 PM
Aaron-71
05-24-2011 03:21 AM
Aaron-71
08-24-2010 11:46 AM
