front tube bumper strength???
I got this bumper off my dad's 78 chevy parts truck. It seems like its made of pretty thick tube. It looks like it would be able to take a pretty good hit and I reinforced it by welding a piece of angle iron from the sides to the frame of the truck. Does anyone have a bumper like this and know how strong it is? Can it take a hit? Could I put a tow rope around it and pull something of get pulled out? It is bolted and welded
It looks pretty strong and can probably take a decent hit. Keep in mind though that the stiffer everythimg is the more the shock loads can be if you hit something. If nothing deflects somethings gonna give somehow.
Can you tow off it? Definitely not at any sanctioned event. I don't know how much that's CYA or how much it's really a good practice, but no off-road club or organization will allow you to use any bumper as a tow point.
How big a hit? I can't say. It's probably similar to a stock bumper if the hit is near a bumper mount, but it'd probably hold up quite a bit better if you hit right in the center, or out on an end, farther awa y from a mount.
Will the front hitch mount to the bumper or the frame? If it's mounted to the bumper a club will still say you are towing off the bumper and won't allow it. I don't know why a bunch of metal welded together and bolted to the frame is OK to tow off of if it looks like a receiver hitch, but it's not OK if it looks like a bumper, but that does tend to be true. And I'm telling you what I've heard from clubs (or read on club web sites). I'm not saying that it's actually safe or not safe to tow off a bumper.
Being welded and bolted to the frame it will probably crack the frame any bigger hit then what the stock could because of it being so rigid.
Like Bob said I would never pull with a bumper done it before with heavy duty bumpers and everything and it never turns out good.
Trav
Trav
on
Yes and no. The PO of my truck welded the bumper to the frame (rear) and it didn't really help anything because once it is in an impact the that extra strength will break the frame. It is almost better to have it just bolted then you have less of a chance of it breaking the frame because the bolts will break first (depending on the strength of the bolts).
Trav
Trav
Trav
Trav
