1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
want to add running lights to my step bars, suggestions for wiring please
Old 12-01-2014, 10:59 PM
tooldad1041's Avatar
tooldad1041
tooldad1041 is offline
I am a trucker at heart and I like to add running lights to my running board / step bars. As far as installation of the lights, done it several times, no problem there. However in the past, I have just ran a wire back to the trailer plug and used a scotch lock / snap connector to feed the running board lights.
if I do the same on a 2012, will that cause havick with the computer? Most likely I will be running 7 lights, all 3/4" diameter LED style.
If this isn't' the best solution, can anyone suggest where to get power for marker lights.
thanks!
Old 12-02-2014, 09:15 AM
weyland426's Avatar
weyland426
weyland426 is offline
I tapped the license plate light wiring as it was the easiest to access. I would also use a small wire loom to protect the wire as you run it along the inside of the frame. But stay away from scotch locks., at a minimum use a good crimp butt connector with shrink tubes. You will have no problem with the extra load with that few of lights.
Old 12-02-2014, 09:53 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
Led strip lights work pretty good. I just have mine hooked up to the door though not as running lights.
The front lights I have hooked into running lights behind headlight. All sealed up with heat shrink to prevent moisture.
Here is my big rig
Old 12-02-2014, 11:16 PM
SD Dually's Avatar
SD Dually
SD Dually is offline
Yes, you can tap into the trailer plug to run your lights. I installed some running lights on my running boards as well.
Like weyland426 said, use crimp butt connectors with heat shrink tubes.
SD Dually
Old 12-02-2014, 11:24 PM
JoeyCap's Avatar
JoeyCap
JoeyCap is offline
I added the dually tailgate light bar and tapped into the license plate lights with no problem.
Those running board lights look pretty cool Bsipes!
Old 12-03-2014, 11:57 AM
MitchPeters's Avatar
MitchPeters
MitchPeters is offline
My 2000 has a round plug on each side that appears to be for the factory lighted running boards that did not come on the truck.
Old 12-03-2014, 12:44 PM
hpwoee's Avatar
hpwoee
hpwoee is offline
That is what I tapped to do my lights above but the only come on when you open the door or turn on your main interior light.
Old 12-04-2014, 12:18 PM
MitchPeters
Makes sense. The factory lights only come on when the interior lights come on.
Old 12-05-2014, 08:39 AM
msgtord's Avatar
msgtord
msgtord is offline
Wired the front ID lamps to the parking lamp, and the rear to the license plate lamp.
Old 12-08-2014, 02:30 PM
Long Haul's Avatar
Long Haul
Long Haul is offline
This member did a really good job with his..
See if this helps you..
2004 F250 Marker Lights
I'm planning on something similar in the same location he used only more of them in a LED like I have on the reefer trailer I pull..
Truck-Lite - Catalog Product : Model 35 Combo Marker & Clearance LED Sealed 5 Diode Pattern
Old 12-11-2014, 05:15 PM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
What lights did you use? That looks great!
Old 12-11-2014, 06:27 PM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
Check out this members thread. He also has a link to a site he runs about how to wire his running lamps along the bottom of his doors.
https://www.ford-trucks.com/forums/1114231-a-few-lighting-projects.html
Here I linked to the exact project. If this is sort of what you are looking for.
http://www.frontiernet.net/~jmray/F250MarkerLights.htm
Old 12-11-2014, 07:14 PM
madsonp's Avatar
madsonp
madsonp is offline
Old 12-11-2014, 07:20 PM
msgtord's Avatar
msgtord
msgtord is offline
"What lights did you use? That looks great!"
Look these up on Amazon.
Maxxima m09300y amber 3/4 round clearance marker lights.
I made my own brackets and I wired them to the right side marker lamp.
Old 12-11-2014, 09:08 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
Heres my setup. I tapped into the trailer wiring. Soldered and shrink wrapped. Been on for a while with no issues so far. Got the lights cheap from a flea market.
Quick Reply: want to add running lights to my step bars, suggestions for wiring please
