HELP 94' f-250 460 where is the 'brain box'
If it's in the same location as my 1996 F350, look under the speed control actuator on drivers side fender lip, you should see a large bundle od wires and a connector on the firewall. On my truck I had to remove all the screws securing the plastic inner fender and pull it down a little bit to be able to slide the ECM out of its place. Good luck! Dale
r9wolves
12-02-2014 10:16 AM
06SUPERDTY5.4
01-21-2008 02:43 PM
Cparker340
06-08-2004 12:40 PM
