seat belt chime
From your owners manual:
Deactivating and Activating the Belt-Minder Feature (Driver Only)
WARNING While the system allows you to deactivate it, this system is designed to improve your chances of being safely belted and surviving an accident. We recommend you leave the system activated for yourself and others who may use the vehicle. To reduce the risk of injury, do not deactivate or activate the system while driving the vehicle.
Note: If you are using MyKey, you cannot disable the Belt-Minder. Also, if the Belt-Minder has been previously disabled, it will be re-enabled during the use of MyKey. See MyKey™ (page 51).
Read Steps 1 - 4 thoroughly before proceeding with the programming
procedure. Deactivate or activate the system by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set.
• The transmission is in park (P).
• The ignition is off.
• All vehicle doors are closed.
• The driver's safety belt is unbuckled.
1. Turn the ignition on. Do not start the
engine.
2. Wait until the safety belt warning light
turns off (about one minute). Step 3
must be completed within 30 seconds
after the safety belt warning light turns
off.
3. Buckle then unbuckle the safety belt
three times at a moderate speed,
ending with the safety belt in the
unbuckled state. After Step 3, the
safety belt warning light will turn on.
4. While the safety belt warning light is
on, buckle then unbuckle the safety
belt. After Step 4, the safety belt
warning light will flash for confirmation.
• This will disable the feature if it is
currently enabled.
• This will enable the feature if it is
currently disabled.
engine.
off.
currently enabled.
currently disabled.
on
engine.
off.
currently enabled.
currently disabled.
engine.
off.
currently enabled.
currently disabled.
2. I have tried the above TNTC (Too Numerous To Count) and it does not work for me. I guess I can stand the chime for a little while.
3. I wish there were a way to disable that g*****n door chime. Now that one drives me absolutely nuts. I just have to take the key out or or flip the latch in the door (actually pretty easy) if I want to leave the door open and key in ignition.
