seat belt chime
Does anyone know how to disable the belt minder chime on a 2015 SD? I tried unplugging the harness under the seat, but it turns on the airbag light. No instructions in the owner's manual like there was for my 2005.
I don't think you can disable them anymore. I just ignore the chime and it will go off after a few minutes.
There is a post in the sticky in the 6.7 diesel forum for door chime. There are instructions within that sticky thread on how to turn off the belt minder.
Originally Posted by 93-331-29PSI
(Post 14851440)
I traced my seatbelt end on a piece of sheet metal and stuck it in so the truck thinks the buckle is buckled
From your owners manual:
Deactivating and Activating the Belt-Minder Feature (Driver Only) WARNING While the system allows you to deactivate it, this system is designed to improve your chances of being safely belted and surviving an accident. We recommend you leave the system activated for yourself and others who may use the vehicle. To reduce the risk of injury, do not deactivate or activate the system while driving the vehicle. Note: If you are using MyKey, you cannot disable the Belt-Minder. Also, if the Belt-Minder has been previously disabled, it will be re-enabled during the use of MyKey. See MyKey™ (page 51). Read Steps 1 - 4 thoroughly before proceeding with the programming procedure. Deactivate or activate the system by performing the following procedure: Before following the procedure, make sure that: • The parking brake is set. • The transmission is in park (P). • The ignition is off. • All vehicle doors are closed. • The driver's safety belt is unbuckled. 1. Turn the ignition on. Do not start the engine. 2. Wait until the safety belt warning light turns off (about one minute). Step 3 must be completed within 30 seconds after the safety belt warning light turns off. 3. Buckle then unbuckle the safety belt three times at a moderate speed, ending with the safety belt in the unbuckled state. After Step 3, the safety belt warning light will turn on. 4. While the safety belt warning light is on, buckle then unbuckle the safety belt. After Step 4, the safety belt warning light will flash for confirmation. • This will disable the feature if it is currently enabled. • This will enable the feature if it is currently disabled. :-RTFM |
tanglefoot9
it took both me and the wife twenty mins to disable my seat belt chime for my 2010. it only gives you seconds to do what it says before you have to do something else, a real pain, but we gut-re done
Originally Posted by redford
(Post 14853722)
Deactivating and Activating the Belt-Minder Feature (Driver Only) WARNING While the system allows you to deactivate it, this system is designed to improve your chances of being safely belted and surviving an accident. We recommend you leave the system activated for yourself and others who may use the vehicle. To reduce the risk of injury, do not deactivate or activate the system while driving the vehicle. Note: If you are using MyKey, you cannot disable the Belt-Minder. Also, if the Belt-Minder has been previously disabled, it will be re-enabled during the use of MyKey. See MyKey™ (page 51). Read Steps 1 - 4 thoroughly before proceeding with the programming procedure. Deactivate or activate the system by performing the following procedure: Before following the procedure, make sure that: • The parking brake is set. • The transmission is in park (P). • The ignition is off. • All vehicle doors are closed. • The driver's safety belt is unbuckled. 1. Turn the ignition on. Do not start the engine. 2. Wait until the safety belt warning light turns off (about one minute). Step 3 must be completed within 30 seconds after the safety belt warning light turns off. 3. Buckle then unbuckle the safety belt three times at a moderate speed, ending with the safety belt in the unbuckled state. After Step 3, the safety belt warning light will turn on. 4. While the safety belt warning light is on, buckle then unbuckle the safety belt. After Step 4, the safety belt warning light will flash for confirmation. • This will disable the feature if it is currently enabled. • This will enable the feature if it is currently disabled. :-RTFM 2. I have tried the above TNTC (Too Numerous To Count) and it does not work for me. I guess I can stand the chime for a little while. 3. I wish there were a way to disable that g*****n door chime. Now that one drives me absolutely nuts. I just have to take the key out or or flip the latch in the door (actually pretty easy) if I want to leave the door open and key in ignition. |
Trace the sound to the source and drill a hole in it. ;)
