Groaning Noise While Turning
So one of two things is happening:
1. I'm paranoid because I just bought my 2011 3.5 Eco 4x4 a month ago and every little thing I hear go bump I stress over...
Or...
2. I've got a control arm/U-joint issue.
When I make turns beyond say 20 degree wheel turn (so almost 90% of turning distances) I hear a groaning type sound coming from the truck. Sounds like it's located in the front suspension area. Sounds like the sound is following the rotation of the wheels though if you can visualize what I mean.
I've had new tires put on since I bought it Oct. 5th but just noticed the noise about a week or two ago. No other work done since purchasing.
Anyone experience anything similar or have any ideas? Thanks
~Mike
Or...
~Mike
First thing I would check is my power steering fluid. If it's okay then try to eliminate variables. Does it make the noise if you are not moving & turn the wheels? Does it make the noise if you first turn the wheels then start moving? Does it only make the noise if you are turning and moving at the same time? Is it safe to assume you are on smooth level ground? If you are not try it on smooth level ground. The truck will make some noise if you turn the wheel all the way to the lock position.
Crystal
The truck was purchased from a lot rather than Ford dealer. Currently there are 55,000 miles on it and I'd planned to take it in soon for scheduled maintenance and will check then.
http://youtu.be/em4uSrBZwIk
I would make sure this isn't the culprit before too much time passes between the purchase and the complete failure. Good luck with it.
I don't believe the 2011 and up trucks use hydraulic power steering, that does not mean they won't have their share of groans and strange noises from the electronic steering rack though.
Please say either #2 or #3...
Only warranty left is 60k powertrain. The groan is almost always. I've been traveling and haven't really had access to the truck but first things first will be running through the checklist of "what could be" as far as obvious things go.
Hoping for the best, or at least not the worst.
~Mike
Well, since you have the LSD, it could be the clutch packs as Big Red has hinted. But it's impossible to diagnose over the internet. If you don't find something else to be the culprit, I'd take it in to let your mechanic diagnose.
If it is the clutch packs, and you are under warranty, there is a Ford TSB for this...
Crystal
