only shift 1-2 but no3-4 on 97 7.3 diesel pwerstroke
im working on 96 7.3 f350 auto. it came in for heavy trans fluid leak found out converter hub is bad and pump bushing. put a rebuild pump and converter. during test drive the truck only shift 2 gears 1-2 no more 3-4 all electrcl conector are plugged in fluid is topped fuses are good.
