HELP!!!! My Ford Expedition Running Board lights, interior lights wont go out!!!
I have a 2000 Ford Expedition, Eddie Bauer. Today, the running boards and interior light will not go out. At first, I had a door ajar light. I sprayed the door switches with PB blaster. At first, when I start to drive away, the Door Ajar light comes on and then briefly goes out.
I pulled the fuse for the interior light and also the fuse from the distribution box for the running boards but the lights on the front doors still will not go out!!!
Anybody have a suggestion?
Well, my mechanic says it is the body control module? Somewhere in the kick plate?
Pulled the battery saver relay and everything goes out, including my power windows. Anyways, he thinks it is caused from water leaking from the windshield. He thinks it's about 500 dollar fix.
Any thoughts?
Any thoughts?
Did you have a lot of rain right before this problem started?
It's probably the driver door. My sable was doing this driving down the road causing a disco party inside. Pulled the door panel and partially removed latch to get to switch. Only took a few minutes. Your lights are staying on because ours have that interior light delay. So every time the switch opens/closes it resets the delay. I'd walk out and look at my 00 but I'm cooking. Can do later if you need more help.
I did pull the #15 fuse to reset the GEM. It seems to have worked - short term.
I don't get a door ajar signal on the the cluster.My mechanic thinks it may be a leak from the windshield. If i pull the battery saver relay, that takes the power away but I don't have power to my windows. Yesterday, after i pulled the fuse and replaced it, everything was fine until on of the passengers turned on one of the rear reading lights and the problem reared its head again. I pulled the fuse again and im back to normal - so far.
Im thinking the problem may be in that reading light~maybe?
Is your windshield for sure leaking? I don't think that's a common problem.
Your first message said you got a door ajar light. That's where I'd start.
What did you spray pb on? The switch is in the top of the latch mechanism, pointing down. At least in the sable it is. It would be tough to spray anything directly into it. The switch is like twenty bucks.
