Did a ton of stuff... no start now.
Just did a egr delete...
oil cooler... New mishimoto radiator. .
Oil change. .. trans change.. All filters. . Cleaned turbo.. did the CAC hoses.. tons to list.
Truck won't start...
2 things..
1. I only unhooked the alt. From the battery. Hood was open for a while.. light bulb was on for a few days.. but that is a small bulb.
Truck has 2 new electrostat batteries when I bought the truck. Need to change those I'm sure as that's an off brand. But they are new.
2. I did a egr delete... with that still plugged in will it cause it to not start?
I went over everything. .. and I'm very meticulous and took my time with everything I did.
Any help would be much appreciated
2 things..
You be the man sir!
Fcim connections were loose.
Fixed!
One more question.
Can I run it without a thermostat for a little bit.. meaning a couple hours.. flush when I get back again... have an estimate to go do.. will it hurt anything? I have straight distilled water with new radiator in it.
Thanks for your help!
Fixed!
One more question.
You be the man sir!
Fixed!
One more question.
Fixed!
One more question.
The turbo seems to be making like a vacuum leak sound. I checked the clamp in the back drivers side as and tighten it some more. I don't want to over tighten it.
Is a small vacuum leak sound normal from that area of the turbo and if not what am.i missing.
She sounds good and runs great otherwise.
You be the man sir!
Fixed!
One more question.
Fixed!
One more question.
Like Tim said, no worries.
