clifford is getting there now.
#2404
#2405
They are arrowcraft steel spacers. There is a lip to properly support the outer wheel. From everything find they are the very best on the market. The only drawback is the outer studs are metric vs the OE 9/16 thread. I will have to buy SD lugnuts in the near future as they are metric. Small taters. I'm so ready to make this part of my project move along its stupid. On a good note the side job in my shop leaves tomorrow and the jeep motor is ready to go in. I'm hoping I'm only a week or 2 away from full swing Clifford tear down........
#2406
#2407
yep. I just mocked up with the 2 inner steelies. I have to strip and restore the Alcoa's so I'm not putting tires on till they are ready and Clifford is apart. His tires are moving over but I still need a truck a bit longer . also he can't go under the knife tillbthe jeep is done.
#2408
#2411
I used aircraft stripper
Then this
Rolite Aluminum Polishing Kit
Start with the Rolite Pre-Polish and a wool pad. Apply just enough product to keep the pad lubricated and work a small area until you have a nice shine. Wipe-off with a terry towel. This may take several applications for heavy oxidation. The Pre-Polish does most of the work, so spend most of your time with this step.
Apply the Rolite Metal Polish with a terry pad or bonnet. Apply just enough product to keep the pad lubricated and work a small area until you have a high shine. Wipe-off with a terry towel.
Apply the Rolite AP300 with a terry pad or bonnet. Apply just enough to keep the pad lubricated and work a small area until you have a mirror finish. Wipe-off with a terry towel.
If you wish to apply the Sealant/Protectant, use a foam pad to spread it evenly across the surface. Wipe-off with a terry towel.
Maintain the shine by applying the Rolite Metal Polish and Sealant twice a year.
Application by Hand:
Use the same application techniques as machine use, but apply all products with a terry pad or cloth.
Then this
#2415
I am curious...is 2" to much? According to my calculations 285/75 vs 235/85 is only a little over a half inch wider .55118 to be precise..
Could you have gotten away with a 1" to 1.5" spacer?
Its really more of a personal preference for me...I not big on the huge gap between the tires.... plus rolling resistance...not that fuel mileage is an issue for you....
