clifford is getting there now.
  #2401
Old 11-19-2016, 09:44 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Looks good, is the spacer safe?
  #2402
Old 11-19-2016, 09:45 PM
tshrager's Avatar
tshrager
tshrager is offline
Originally Posted by fordman67
Purty!
Hell yes! Looking good!
  #2403
Old 11-19-2016, 10:53 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Awe shoot! Looking sa-weet!
  #2404
Old 11-19-2016, 11:30 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Whoooooooop!! Tough sumbitch
  #2405
Old 11-20-2016, 01:18 AM
fordman67's Avatar
fordman67
fordman67 is offline
They are arrowcraft steel spacers. There is a lip to properly support the outer wheel. From everything find they are the very best on the market. The only drawback is the outer studs are metric vs the OE 9/16 thread. I will have to buy SD lugnuts in the near future as they are metric. Small taters. I'm so ready to make this part of my project move along its stupid. On a good note the side job in my shop leaves tomorrow and the jeep motor is ready to go in. I'm hoping I'm only a week or 2 away from full swing Clifford tear down........
  #2406
Old 11-20-2016, 07:56 AM
tshrager's Avatar
tshrager
tshrager is offline
Are the 285's on 4x2 steelies?
  #2407
Old 11-20-2016, 08:57 AM
fordman67's Avatar
fordman67
yep. I just mocked up with the 2 inner steelies. I have to strip and restore the Alcoa's so I'm not putting tires on till they are ready and Clifford is apart. His tires are moving over but I still need a truck a bit longer . also he can't go under the knife tillbthe jeep is done.
  #2408
Old 11-20-2016, 10:52 AM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
'74 Ford 250 CS is offline
Curious to know how your going to restore your Alcoa rims? I'd like to do mine in the future.
  #2409
Old 11-20-2016, 11:38 AM
fordpride's Avatar
fordpride
fordpride is offline
I stripped mine then polished them and clear coated
  #2410
Old 11-20-2016, 11:45 AM
oldbird1965
What products did you use Mike? Mine are in bad shape.
  #2411
Old 11-20-2016, 12:01 PM
fordpride's Avatar
fordpride
I used aircraft stripper
Then this
Rolite Aluminum Polishing Kit
Start with the Rolite Pre-Polish and a wool pad. Apply just enough product to keep the pad lubricated and work a small area until you have a nice shine. Wipe-off with a terry towel. This may take several applications for heavy oxidation. The Pre-Polish does most of the work, so spend most of your time with this step.
Apply the Rolite Metal Polish with a terry pad or bonnet. Apply just enough product to keep the pad lubricated and work a small area until you have a high shine. Wipe-off with a terry towel.
Apply the Rolite AP300 with a terry pad or bonnet. Apply just enough to keep the pad lubricated and work a small area until you have a mirror finish. Wipe-off with a terry towel.
If you wish to apply the Sealant/Protectant, use a foam pad to spread it evenly across the surface. Wipe-off with a terry towel.
Maintain the shine by applying the Rolite Metal Polish and Sealant twice a year.
Application by Hand:
Use the same application techniques as machine use, but apply all products with a terry pad or cloth.
  #2412
Old 11-20-2016, 12:30 PM
fordpride's Avatar
fordpride
Crap pic but you get the idea
  #2413
Old 11-20-2016, 05:28 PM
oldbird1965
Thanks Mike, its on my winter list! Reps sent.
  #2414
Old 11-21-2016, 07:01 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
I giggled at the spacer post on fb. Looking good Aaron! And thanks Mike!I needed that write-up for my rims.
  #2415
Old 11-21-2016, 09:42 AM
lee00's Avatar
lee00
lee00 is offline
285s are wide but that 2" spacer is perfect
I am curious...is 2" to much? According to my calculations 285/75 vs 235/85 is only a little over a half inch wider .55118 to be precise..
Could you have gotten away with a 1" to 1.5" spacer?
Its really more of a personal preference for me...I not big on the huge gap between the tires.... plus rolling resistance...not that fuel mileage is an issue for you....
Quick Reply: clifford is getting there now.
