1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 F250 V10 starting issues
Old 11-20-2014, 02:20 PM
pointerman1967's Avatar
pointerman1967
pointerman1967 is offline
My 2000 F250 with the V10 is having some seemingly random starting issues. Truck is cranking hard, so I am fairly sure it is not a battery issue (battery is only two years old). There are times when it will just crank and start after a minute or two of trying. Truck seems to run perfectly after it starts. What should I be checking? Can the fuel pump randomly not work and then work again because I twice it has started only to stop almost immediately and then start again a minute or two later. Some sort of electrical issue I need to look at? Would prefer to try and repair this myself rather than spend a fortune on a mechanic to diagnose.
Old 11-20-2014, 05:21 PM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
Here are two suggestions;
1-Change your fuel filter (if it is not already replaced during the last 30K miles),
2- Buy a "fuel pressure gauge" and see if you have approx. 30-35 psi fuel pressure at the fuel rail while cranking, when it fails to start ( fuel pump ? )
good luck,
627sdgg
21
03-02-2021 05:41 AM
Dennis Silva
09-23-2018 07:36 AM
kjeremiah
03-24-2011 09:09 PM
jreg
Modular V10 (6.8l)
12-19-2008 07:40 PM
Ronbp
06-02-2008 04:42 PM
Quick Reply: 2000 F250 V10 starting issues
