Fel-Pro maiden voyage
11-19-2014, 02:47 PM
Former Vendor
on
We are on live about to open a pair of Fel-Pro hg's. the customer supplied them and said he would be the test subject. I said they are the only set I would even consider doing if not doing Ford blues. I guess time will tell if they are up to par.
11-19-2014, 03:11 PM
subscribe--If I needed some I'd be a guinea pig too. I just can't see Fel-Pro putting out an inferior product--but then again as you say time will tell.
11-19-2014, 03:53 PM
I think I'm going to use Cometic when the time does come......if it does,if it anit broke why fix it?
11-19-2014, 05:02 PM
All I am gonna say is in all the years I have made my living turning wrenches I have never had reason to complain about FelPreo. At one time or another I have found something FelPro in every Full gasket set from every auto maker.
11-19-2014, 05:43 PM
In my many years, more than I care to count, I've never had a defective Felpro product.
11-19-2014, 05:55 PM
All I see is Anthony raiding the fridge...
11-19-2014, 06:03 PM
O'Rileys is stocking them for $59.99 each. Quite a cost savings if they prove out. Really hoping the work well. good Luck!
11-19-2014, 06:24 PM
The main thing that I'm saying is that if I didn't use OEM, Felpro would be my next choice.
11-19-2014, 10:25 PM
Certified Thread Hijacker
Quote:
Originally Posted by
69cj
Plenty of defective Print-o-Leaks for FE Engines...
Josh
11-20-2014, 02:56 PM
Bullitt390
Josh
Bad manufacturing run, materials or design?
11-20-2014, 03:05 PM
OK I am haveing an altimers moment what is a FE engine.
11-20-2014, 03:07 PM
MisterCMK
Bad design. There is now an updated Print-o-Seal intake gasket with a metal core.
They still offer the old style which is prone to breakdown. And they have the original embossed style that works extremely well.
Josh
11-20-2014, 03:09 PM
dannyboy950
332 352 360 361 390 406 410 427 428
Josh
11-20-2014, 03:17 PM
Bullitt390
Josh
you posted the big block numbers so had to look the FE up--"FORD EDSEL" engines--never really paid attention to that
11-20-2014, 03:19 PM
KDAVID1
Well, there's debate to what FE actually stands for. Ford-Edsel is one of the most common.
Josh
