2001 F-250 Super Duty V10 Leaking Bad Oil Leak
I have been leaking oil on one of my work trucks. I do not know what the part is called or named. the leaks seems to be coming from above or behind a part that the driver side motor mount. As you can see in the image, the part has a sensor and a concave dip that runs along the middle of it. Well, I stuck my fingers behind that and it has a dip on the other side too which face up and that dip was puddled with oil. I need to know what that part is called or named or what is directly behind it that can be causing the leak. I hope its just a gasket and it is not cracked.
Part that is leaking behind. 2001 Ford F-250 Super Duty V10
Found What I Was Looking For
Nevermind. Noticed Many of you stopped by to at least read my post. Thanks anyways. I found the name of the part. It's called the Oil Filter Adapter. The problem is just the Gasket. I found a similar thread here for an F-350:
https://www.ford-trucks.com/forums/876424-oil-leak.html
A few more beers and it's time to get dirty.
