F-100 1954 cab & tray over a 1972 F-100 chassis
Hey all, I have this 54 F100 thats sitting on a 72 chassis width is the same but length of wheelbase out by 127mm ( 5 inches ) . Have sorted that out and can move the rear springs / mounts / axle forward enough to match specs ( and take out the gap between tray and cab )
I thought maybe while I'm at it I could drop the height of the chassis to get that lowered mean look.
The rear shackle is pretty close to the bed now but the front one has plenty of room to move up if I flip it over .
I havent done any of this yet but have looked and notice that the angle of the diff changes with the front shackle moving up that much . Ok yes if the rear one moves up the same it would work but it would have to
poke through the bed ( not a good look ) .
Will the diff being on a tilted up angle , effect the drive shaft behavior ?
inverted shackle front
normal position of shackle
Normal diff position - slight angle
Lowered position - angle increased
Received 4,132 Likes
on
on
How much difference is there in TRACK between 54 front end & 72 Front ends ?
No , I got wheelbase ( length ) correct now, I moved the rear springs / axle assembly forward 127mm ( or 5" for you guys ) .
How much difference is there in TRACK between 1954 front end & 1972 Front ends ? ,
I cant find info , just that 110" & 115" dimension which is Wheelbase of course
