DOT5 Brake Fluid
DOT5 Brake Fluid
I am in the process of restoring my 1979 F150 4x4 and wanted to see if I could use DOT5 brake fluid in my truck instead of DOT3. DOT5 does not absorb water over time and is not corrosive. I have replaced both front calipers, both rear brake drum cylinders, all brake lines, and the master cylinder so none of the brake system components have had any brake fluid in them yet. Can I use DOT5 brake fluid?
