Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2012 Escape reset low tire pressure light
Old 11-16-2014, 08:02 PM
leafswin's Avatar
leafswin
leafswin is offline
I just put on new winter tires and rims on my 2012 Escape and after driving about 6 miles, the low tire pressure light came on. Is there is a procedure to learn the vehicle to the new tires? Anything document on this?
Old 11-18-2014, 02:04 PM
FordServiceCA's Avatar
FordServiceCA
FordServiceCA is offline
Official Ford Rep
Originally Posted by leafswin
I just put on new winter tires and rims on my 2012 Escape and after driving about 6 miles, the low tire pressure light came on...
Thank you for reaching out, leafswin. Based upon the owner’s manual, the low tire pressure warning illuminates when your tire pressure is low. If the light remains on at start up or while driving, the tire pressure should be checked. Refer to Inflating your tires in the Tires, Wheels and Loading chapter. When the ignition is first turned to on, the light will illuminate for three seconds to ensure the bulb is working. If the light does not turn on or
begins to flash, have the system inspected by your authorized dealer. Please find helpful tips on pages 15, 189, 190, 191, and 192, using this link: http://www.fordservicecontent.com/Fo.../12204og2e.pdf I’ll be here if you need me.
Kwasi
Old 12-12-2014, 06:41 AM
frosty134's Avatar
frosty134
frosty134 is offline
Re:2012 Escape TPSM
I came across the same issue in my 2011 Escape. I came across a fix, that I have yet to try, but others had.
1) Pressing the hazard warning button 6 times. Horn will honk.
2) Dash will display will show "train left front tire".
3) Release air from tire until horn honks.
4) Dash display will show "train right front tire"
Follow this procedure for all tires. TPMS is supposed to "trained"
Fill your tires to the recommend pressure.
Old 12-12-2014, 12:28 PM
wptski's Avatar
wptski
wptski is offline
That's the procedure which might vary by vehicle but I fairly sure that it requires a training tool at least. At one time Ford included the basic training tool with the F-150. I got one off eBay for around $30. I waited too long to pick one up, they were around $20 earlier.
Old 12-12-2014, 03:51 PM
frosty134's Avatar
frosty134
TPMS Failed Attempt
Well I tried my own suggestion, and after getting one tire down to 20 psi, I gave up. The Escape then polity told me that the training had failed!
Ill shop for a Tool!
Old 12-16-2014, 12:40 PM
wptski's Avatar
wptski
wptski is offline
Got a TPMS Sensor Fault today! All were around 26/27 PSI but I raised them to 31 PSI anyway. The L/R wouldn't train, tried twice. It's off to the dealer tomorrow and that's three out of four OEMs gone bad. I "once" knew were the two new ones were but I forgot to it down after one oil change.
Using the 8C2Z-1A203-AB tool. I think this replaced the 8C2Z-1A203-A tool.
Old 12-16-2014, 01:29 PM
frosty134's Avatar
frosty134
And I am going to my local Discount store and get a 1'' yellow happy face and place is directly over the dash sensor light. So when I look down, I'll know to "don't worry, be happy"
Cheers
ssmandavid
1999 to 2016 Super Duty
02-04-2016 08:35 AM
mebe2k
6.7L Power Stroke Diesel
33
11-15-2015 10:56 AM
Nickf1989
01-01-2013 07:33 PM
drifter
03-14-2011 06:44 AM
El Jim
1983 - 2012 Ranger & B-Series
07-05-2010 08:47 PM
Quick Reply: 2012 Escape reset low tire pressure light
