Camshaft timing "HELP"
Just turn the engine clockwise until the driver's cam timing mark is up before you put the right cam back in. If you are sure the driver's cam is in time then just make sure its timing mark is at the top and not 180 degrees out. The crank mark will line up with either of the cam marks. It's possible to time the right cam correctly when the left cam is 180 out but the engine wont run.
Mikerage
1997 - 2003 F150
30
07-29-2016 02:59 PM
camargleandro
1999 to 2016 Super Duty
01-07-2010 08:59 PM
