351w cylinder head removal
Old 11-10-2014, 08:29 PM
Gigemags05's Avatar
Gigemags05
Gigemags05 is offline
1982 351w. I have removed all the head bolts and the head absolutely will not move.
I tapped lightly with a hammer, tried getting a screwdriver in to pry it up and had no luck.
I also tried to thread a bolt into the holes on the end to give me some leverage to pull up and the head will not budge at all.
Is there something I am missing?
Old 11-10-2014, 09:17 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
A pry bar at the corner should break it free - assuming all the attaching pieces have been removed.
Old 11-10-2014, 09:27 PM
Gigemags05's Avatar
Gigemags05
Which corner? I couldn't really find a spot that a pry bar would fit.
I am pretty sure everything is disconnected. I took the intake and exhaust manifolds off, took alternator, etc off.
I took the head bolts out.
The only thing that could possibly be holding the head on are some set screws located in between the valves on the head (pictured below). Do I need to figure out a way to remove those? I did not have to do anything like that with the other cylinder heads I have worked with.
Old 11-10-2014, 10:00 PM
RL250's Avatar
RL250
RL250 is offline
I strongly advise against messing with those. They seal the water passages. Same with my M block.
Try to slowly and carefully work on the corner near the end of the valley. You see the curve where the intake seals? It should be flush with the deck/head mating surface. Also, you could try a putty knife and hammer to seperate the two. I had to jimmy a transmission case that way.
Old 11-10-2014, 10:17 PM
Gigemags05's Avatar
Gigemags05
Yeah I didnt think I needed to mess with those set screws.
I guess I'll continue to try and pry the head off. I'll try on the corner with a putty knife
Old 11-10-2014, 11:24 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
In the past with engine tear down's, I have had to put a prybar in an intake port and pry outwards. Pops them off pretty easily. Don't be a gorilla with the prybar in any port.
Old 11-10-2014, 11:33 PM
bruno2's Avatar
bruno2
bruno2 is offline
Each head should have two alignment dowels between the block and the head. So the head will not slide in any direction. It will have to be pulled upwards. If you still have cherry picker you can use that to pull it off.
Old 11-11-2014, 08:19 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
No, don't mess with the allen-head plugs.
A putty knife isn't gonna do it, even a screwdriver could be difficult. Use a pry bar or other long, kinda-large lever to pry up on a front corner where it meets with the block.
Old 11-11-2014, 08:25 PM
Gigemags05's Avatar
Gigemags05
I was able to finally get them both off this evening using the cherry picker and a pry bar.
It was very difficult. At one point the cherry picker lifted the entire engine and stand off the ground.
There was all sorts of gasket maker on it. Would it have come from the factory this way? Everything looks like its in really good shape. The engine has 90,000 miles on it but I am wondering if someone has been in there to do some work already.
Old 11-11-2014, 08:51 PM
RL250's Avatar
RL250
RL250 is offline
Someone has been in there. Factory does not use gasket maker for heads.
Old 11-11-2014, 09:36 PM
Gigemags05's Avatar
Gigemags05
Thank you for confirming that.
Now I'm wondering why someone had been in there.
I am planning on replacing the cam and valve springs, lifters, etc. Is there a way to see if those things have already been changed?
Old 11-11-2014, 10:10 PM
bruno2's Avatar
bruno2
bruno2 is offline
Chris Tibutis likes to use rtv or gasket maker on heads. However, that is not the way to do it. Nothing should be used other than the gasket. The oldtimers would use silver spray paint or maybe K&W copper coat.
Don't lose the alignment pins!
Old 11-11-2014, 10:15 PM
bruno2's Avatar
bruno2
bruno2 is offline
You have got crap all down in the valley. I bet that stuff has made it's way into the lower end. It may be a good idea to do an entire disassembly. I would put new bearings in the lower end if I did that. Maybe someone else will chime in and say if I am talking nonsense or not.
Old 11-12-2014, 06:00 AM
RL250's Avatar
RL250
RL250 is offline
I was referring to using the putty knife to merely break the seal. You'd still need to pry it off afterward.
Old 11-12-2014, 08:06 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Originally Posted by bruno2
Chris Tubutis likes to use rtv or gasket maker on heads.
Yeah, man! Especially on the coolant passages, what easier and better way of blocking coolant flow than that?
https://www.ford-trucks.com/forums/7...ssageways.html
Quick Reply: 351w cylinder head removal
