1991 F150 timing issue
I'm new to Fords and I recently bought a 1991 F150. I like to know what any new vehicle I buy is about so I proceeded to put a new cap, rotor, plugs and wires and its runs like crap since. It now has a low rpm miss in od and it has to drop back a gear. I want to check the timing but my Haynes manual says to "unplug the spout". What the heck is a spout? Any other thought as to what might be causing the miss?
Here's a pic I found of what it looks like. Hope this helps you out.
When you place the spout connector back in, if you toss the timing light back on it the timing position may look like it's off, but once that spout connector is put in, it retains it.
I used to advance my timing by 10 degrees to do a little drag racing, before I added 10LBS of boost to the stang.
Hope this helps you out,
Tony
