Carb Spacer
Carb Spacer
The vacuum connection for the PCV system on my Y sits right in front of an idle adjustment screw on the carb--there's no way to get to it. I'm considering a spacer under the carb (2V--unknown brand), but unsure about the type and material to use.
Looks like aluminum or phenolic is available, with either an open or 2-hole design. I think about 1" would be enough space to clear the fitting.
I've heard that spacers can change the performance characteristics a bit, but didn't notice any difference when I put one on a 390 a while back--though my first attempt with an open style spacer caused a nasty whistle under some conditions.
Anyone else been down this road, can offer some advice?
~Steve
~Steve
I swapped spacers and never could tell any difference in performance either. Just be careful if you buy a cheap one like some chain auto parts stores sell, I've found ones that are anything but flat when checked with a straight edge. I prefer phenolic, I just feel they transfer less heat..
rockcrawler_101
06-27-2011 02:55 PM
Andy_Bracy
19
12-16-2005 08:08 PM
79F150400M
07-17-2004 03:18 AM
