My excursion trailer build
So i haven't been on in awhile (life been busy)
Not sure where to post this but, thought most of you know my rig, here was fitting.
As most of you know i purchased this a couple months ago, havent made much progress till just recently
Here is how I am making my bolt pattern match the X
Better shot of body damage that needs repaired
Had to remove whole panel to work it better
Crappy cell pic but a lot straighter than before
The wife picked up the steel for the frame while i was on the road, it's 3x4x.120wall except for the tongue which is 3x3x3/16
Cutting steel
Went to weld it the same day I cut it but, my machine was broken. Ended up being a contactor and some other small parts ($450) lol
3 weeks later got my machine back, couldn't wait to melt some metal together
Welds aren't to bad for not welding seriously in a bunch of years
Almost all done but running out of daylight
The wife even tried her hand at welding for the first time
Not bad for her first weld
Here is my custom superduty trailer axle with matching bolt pattern, brakes and parking brake.
HaHa 16" of ground clearance
No leafs yet, just testing height of frame and clearances
Wow what a work out with only 2 of us getting the frame under the body
After about 2 hrs of wrestling got it on
Had to see what it looked like behind X, It's far from road ready but a huge milestone.
Currently it has 30" of ground clearance at the frame, I think thats enough
Cutting steel
The main purpose of the trailer is going to be an adventure/camping trailer, eventually it will be able to be off grid for at least a week or so.
Plans are to include water storage(50+gals), solar charging for 4-6v(wired for 12v) amg batteries, water purification and heater, sink, shower(free standing type), and stove/oven and a couple off RTT(roof top tents,one for the kids and one for the wife and I)
The main reason for not using a pickup frame was weight and also I can customize where i need the cross members for under body storage tank(water and fuel)
My guess is clearance to the tow rig, easy of accessing the rear cargo with the trailer hooked up, and maneuverability - especially while backing up. Short trailers with a long tow vehicle can be a wee bit uncooperative when reversing. Trailer turns on a dime, rig doesn't lol.
On second thought, WTF Ray is a professional semi driver. He knows what he is doing. Carry on Ray.
Last edited by mecdac; 11-03-2014 at 08:33 AM. Reason: Self punishment for not thinking.
It will have a spare mounted standing up(on the left side),2-20# propane tanks on the right side and then a box with 4-6v batteries in front of that. After all that is on the tongue, I still wanted to be able to jack knife the trailer if needed. The trailer from tongue to center of axle is only about 3" shorter than the wheelbase of the X.
