72 Ford F100
#46
#47
I believe the truck-lite headlights are built to milspec (whatever that means). Have not heard many, if any, references to them failing. I specifically made a point of pulling my LED truck-lite headlights and passing lamps when I traded to a newer bike a couple of months ago.
#48
Are you saying halogens would be brighter than LED? I know they use more energy, but not sure they are necessarily brighter. If I had the bucks, HID-based headlights (with the correct refractor/reflector?) would be my first choice.
#49
I don't think they are but I do know that they are considerably more expensive than $7 halogens. Either way the relays will provide full voltage to the headlights and more lumens. Daniel Stern Lighting Consultancy and Supply
#50
#52
#53
#54
So I went ahead and picked up the rear taillight LEDs and they are pretty dang bright. I can post up a pic of them in my hot little hands and I will put up a before/after picture here Friday. I also got a carb kit and thermostatic choke so I will be all set for the weekend to do things.
I will look into the hallogen conversion, the LED's are a little too rich for my blood considering how much I have into the truck currently. I will do the alternator swap as soon as I can get some parts sold off my Lincoln (if you need 90-97 lincoln towncar parts I might have pulled something off you need).
NEVER!
NEVER!
#55
would someone know how these draws compare to our stock headlights:
12.8v, 1.80a (low beam), 3.60 amps (high beam)
Interesting review of using these phase 7 headlights on a bump:
How to Install LED Headlights - Cole's Hot Rods | Cole's Hot Rods
#56
So in doing an H3/H4 conversion I could probably risk running an HID setup (not in a funky color of course).
Maybe I could get a sponsor and they send me the LED headlights! HA!
Where would I buy a headlight relay or is this wiring I gotsta do on my own. I figured maybe O Reillys or Autozone might carry an H4 conversion?
#57
#58
on
That could also take you out as well when thinking only of yourself not seeing the road at night driving..
They can't either.
I see many guys selling their use HID setups on C/List for some reason.
Maybe a fit it ticket changed their mines, and just removed them to pass.
But it's their money..
Very annoying tho!
Orich
#59
Also great for blinding on coming vehicle drivers.
They can't either.
Very annoying tho!
Orich
They can't either.
Very annoying tho!
Orich
#60
I acquired an HID setup for my Harley three or four years ago. It was one of those that "replaced" the existing bulb using the existing housing/reflector.
I was unimpressed. If I had the correct reflector things would have probably been different. Did not like the extra stuff needed for running it either.
