72 Ford F100
#31
Took her for a couple drives to get used to her. I got everything but the damn first gear down The first drive I had a loose shifter, a sticky accelerator pedal, a too tight steering wheel, a unattached vacuum hose and turn signals that didn't want to cancel for me. Killed it...more times than I'd care to admit, once in the middle of traffic because out of panic I moved from the clutch to the brake (i'm a *******). Changed ye ole oil, got everything fixed up but too dark to go for another test drive.
Today: Stuck mostly around the block trying to get my first gear usage down. But there was also 4 inches of snow on the ground. Spun it once, killed it once. Improvement! Also much easier to turn now that I'm not dancing on the pedals trying to get the accelerator to not stick.
In result I didn't take it down to Ark City with me on account of the snow. But everything is A-Okay.
#32
#33
My problem currently is the take off in 1 st gear (the right amount of clutch vs gas). I'm more or less learning to drive stick for the first time (I got the emergency crash course whenever I got my learners permit, but that was in a five speed and included a lot of 3000 rpm clutch dumps to get the darn thing to move).
I must've got a good linkage or you got a cruddy one because the engagement is butter smooth and is super easy. I think it is better than the 5 speed that I got the crash course on. Granted if/when any performance upgrades are being added, the shifter will have to be moved to the floor because there is no way in hell I can drive that thing in anger. But for taking it at a moderate pace and a relaxing cruise, no problem.
#34
I learned to drive in a Ford Galaxy 500 with column shift about 40 years ago. Had not driven one hardly at all until March when I got my 71 f100. Kind of enjoy it. Now even more in the 69 because of the better running engine and soft clutch. Do need to look up what all one should service on the column shift.
#36
#38
Well the insurance did not pay out on my towncar, so I am swapping the 2000 mile tires onto the truck and putting the 31's on the TC so it can be a roller. That should save me a bit of weight (always a good thing) and get me a little bit of rear gear back. As long as the weather agrees with me I will have a truck back in Ark City.
#39
Hey guys, so I put on the 215/70/r15 tires on the truck and it makes driving it so much easier. The truck now turns pretty easily and accelerates much better. So I have some plans for this truck finally.
Initial:
Hook up E-brake
U joints
Carrier Bearing
Brake Lines
Brake Fluids
Rebuilt 2 BBL (maybe)
Warmer Weather:
Cab Mounts
Floor Pans
Carpet
Newer Bench Seat
Will the older metal steering wheel bolt right up to the column or is there something else that needs to be changed out?
Initial:
Hook up E-brake
U joints
Carrier Bearing
Brake Lines
Brake Fluids
Warmer Weather:
Cab Mounts
Floor Pans
Carpet
Newer Bench Seat
#40
#41
Initial:
Hook up E-brake
U joints
Carrier Bearing
Brake Lines
Brake Fluids
Warmer Weather:
Cab Mounts
Floor Pans
Carpet
Newer Bench Seat
Initial:
Hook up E-brake
U joints
Carrier Bearing
Brake Lines
Brake Fluids
Warmer Weather:
Cab Mounts
Floor Pans
Carpet
Newer Bench Seat
JYs tend to be slow in winter so it's a good time to shop for parts like the bench seat.
A 72 uses the 71-77 steering wheel.. the early versions 67-70 are the same as a 63-70 Falcon... Around $175 as a reproduction... they're not steel per se...they are steel framed with cast plastic.
I don't recall whether the issue was with updating or backdating steering wheels but do recall some difference with the steering shaft and some guys having to hack off the unthreaded nub because it interfered with the born button...
#43
Guys, this truck will probably see many a rural roads at night. What are some lighting options I can do to it to keep it stock and make me a little more visible. Eventually I am going to get a roll bar and put auxilary lighting on it, but not right off. So my plan was:
Taillight 1157 Red LEDs in the back
Turn Signal 1157 Amber LEDs in the front turn signals
But I have yet to find something to help my forward visability. Help me spend some money to hopefully not get in another wreck that lead me to get this truck.
#44
Aren't these essentially 7 inch round headlights on our trucks?
You know I would expect something like the Truck-Lite (27270C) Headlamp would work. I run one on my Harley and what an improvement it made. Additionally, they take less juice to power, so they are not as demanding on the charging environment. They are pricey. I paid about $200 or more for mine a couple of years ago. They just plug in with a standard 3 prong plug.
#45
