Old truck, mo' problems
I just recently acquired a 1959 F100 stepside shortbed, It was sitting for two years before I bought it and I got running in 8 days (had help). I tore the carb apart and got a rebuild kit for it, but the bowl still slightly leaks, I also put about 7 gallons of gas in it last week and it all ended up in the motor block, gas cap is vented so what would fix those two issues. The float also seemed to be in ok shape but the bowl is very pitted.
If the bowl is leaking that bad, the faces are probably warped. Which carb, the Holley 1904? If so, take it back off the truck and use a straight edge to check how flat the mating surfaces are. If they aren't flat, you may be able to help the ears back into position with some heat, a vice and maybe a small hammer. Google for Holley 1904 leaking fuel... there's a guy with a video to show you how. The other things that can happen is if the needle valve on the float is scored, it won't seal and you'll over fill the bowl.. which spills out, but usually results in rough running engine. Just a quick check... what kind of gasket are you using at the bowl?
7 gallons of gas in it last week and it all ended up in the motor block.
Chances are if you had 7 gallons of fuel in the crankcase, the fuel pump diaphragm is leaking as someone mentioned above. If the truck was parked nose down and the carb was leaking, you could have some gas in the crankcase, gravity siphon feed.
welcome to the orphanage Outlaw, you are going to be a pro at these 1904's in no time! these guys have you on the right path and I will not interfere sir.
Pics, we need pics-lots
oh yea, this page will help ya too--- http://www.carburetor-parts.com/Holley-1904_ep_320.html
Welcome to Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store
All right I appreciate it guys, I will get pics on tonight as well it's, originally April green but now is black, it,s peeling from sitting in the sun for so long so is staring to resemble an April green Dalmatian.
And ok no silicone seals then, but I will take it off and check the float and power valve. Good ol folks at oriely's said I oughta run some cheap oil through and consider putting a shut off valve on the stainless steel line running to the carb before putting new oils or any new amount of gas.
