CPP Under Floor Booster/Master - Built In Residual Valves?
Residual valves are used even with firewall mounted MC's. The popular '67 Mustang drum/drum MC came with them from the factory. Their purpose is to reduce pedal travel by keeping the shoes/pads close to the drum/rotor, but not so much that there is a lot of drag. It also reduces air getting sucked in around the wheel cylinder / caliper bore seals.
A firewall mounted reservoir on one of our trucks is "maybe" 2-1/2 ft higher than the stock MC, which puts a little less than one psi pressure at the MC.
Residual valves are used even with firewall mounted MC's. The popular '67 Mustang drum/drum MC came with them from the factory. Their purpose is to reduce pedal travel by keeping the shoes/pads close to the drum/rotor, but not so much that there is a lot of drag. It also reduces air getting sucked in around the wheel cylinder / caliper bore seals. A firewall mounted reservoir on one of our trucks is "maybe" 2-1/2 ft higher than the stock MC, which puts a little less than one psi pressure at the MC.
Ain't nothing that can't be undone if necessary!
Good job. I had read something similar since starting this thread, so seems like you can take it to the bank and save yourself $20 on the rear residual valve. I also read that it doesn't matter if you have two...hopefully that's true
I believe from all the discussions, you have figured this out now.
Personally I used the exact same set up of under floor master that is in your picture and installed a residual valve in line for both the front and back on my 56 F100 along with a remote reservoir installed in cab behind seat.
Have run this for nearly 10,000 miles now and no problems, brakes work fantastic..
Good luck and good trucking.
I believe from all the discussions, you have figured this out now. Personally I used the exact same set up of under floor master that is in your picture and installed a residual valve in line for both the front and back on my 56 F100 along with a remote reservoir installed in cab behind seat. Have run this for nearly 10,000 miles now and no problems, brakes work fantastic.. Good luck and good trucking.
I just have a few more parts to get and I will be in business.
I can't be sure, because they were on eBay and didn't have a manufacturer listed or any markings on them.
But I can't help but notice they look exactly like these...
Scottshotrods | Scott's Hotrods Remote Reservoirs - Scottshotrods
I got a good deal ($50) but even the $135 (for triple) on the above website seems like a pretty good price!
#29
Howdy neighbor!
http://www.summitracing.com/parts/wi...2697/overview/
#30
Thanks. I will check those out. I am thinking about what you have or these.
